Author Topic: Non thumper- compressor seals!  (Read 5771 times)
guest40
Re: Non thumper- compressor seals!
« Reply #15 on: April 02, 2009, 02:52:43 AM »
Just a quick note. If you can find some way of attaching a filter to the inlet port of the compressor, you will get much longer service life from the pump. The area the comressors are usually installed in is prone to high dust and contaminanats. This dirty air is what probably destroyed your compressor in the first place. A good source for a filter is as simple (and cheap) as a sintered plastic silencer, available from any good reputable pneumatic equipment supplier. The plastic ones are much more suitable than the brass ones as they have a much larger surface area for thread size and far cheaper. I used a 1/4 bsp silencer to an adapter on the Magna/Ford compressor.  You may need to play with the attachment method.
More ...for the Rangie/Disco owners
When I owned my last Rangie, the pssweak vacuum valve for the centre locking diff gave up the ghost. This was due to the wear in the chicken sht quality valve caused by dust ingression over the years. I replaced this valve with a 5/2 1/4" lever operated spool valve. I used the above silencers on the exhaust ports which, under vacuum become the inlet ports. this system outlasted the vehicle. I still have all the valves etc. Direct action soleniod valves can be used but can be tricky to set up, tho it can be activated by a toggle switch on the dash.
even more to twist CG's mind,
If anyone needs to convert a standard M/C gearshift to handlebar control, eg disabled rider, I worked out the circuits for a disabled Quad racer a few years ago when I was flogging pnuematics. however the rear braking circuit was next to impossible to setup.
« Reply #16 on: April 29, 2009, 11:53:18 AM »
The upshot of this (for anyone interested)
Managed to get a *brand new* Range Rover P38 compressor.  Bodged on initially with jubilee clips and *very* strong hose.  Result!  Did 600 miles over a weekend.
Now a better solution is the hose I got Pirtek to make me so that the metric fine outlet on the RR pump plumbs into where the emergency schradder valve used to be on the LDV unit.
Thus I can keep the DOWN solenoid and the air dryer.
I suspect the relays/ECU has failed, as once inflated, the solenoids click, but the pump keeps running.  So I'm reckoning this is the cause of death for the old compressor: sheer exhaustion!
So for now its a manual system.  Approx 3 mins compressor running per 100 miles of motorway travel (approx 2h).  And has he wired a switch?  No, but the fusebox is very easy access while driving!
cheers all for your advice, very much appreciated
« Reply #17 on: April 29, 2009, 06:43:06 PM »
厚木は私の新しいもの、しかしだれでもwho'であり; リーズの私達へのdの話は日本に話してがまずなかった。 LDVは不可解な原料、I'をした; llは未決定リストにこれを加える温度の内部は要因、そうニトリルのOリングwon'である; tの最後の長い。負荷が奇妙であるのでECUにタイヤの圧縮機を接続することに混同したそれがある。 HTのゴムは過フッ化炭化水素またはエピクロロヒドリン(黒)である。あなたのローカル気体力学の店にHTの使用のためのOリングがあるかもしれなかったり頻繁にシリコーンゴムである(赤い)。赤いOリングが幾つかポンド、多分1つを試みなさい。それに水平になる弁があるまたは乗車の高さは電気センサーから置くためにあるか。ちょうどそれが水平になることを必要とするまたは異なった高さに行く必要があるか。 1つの高さは圧縮機でより容易である。 you'なら; ve水平になる弁をおよびよりよい小さい貯蔵所まだ得、ECUのヒューズを引っ張り、3 bar/40 psiにタイヤの圧縮機で貯蔵所を満たし、そしてドライブのために行く。 30分をすることができ、/20マイルタイヤの圧縮機大体レベルであることは仕事までおよびそれでもあれば走るためにちょうどそれを誘発するように圧力スイッチを装備する必要がある。 それwon' tはタイヤの圧縮機を越えて、使用率ある。使用率はそれに住んでほしければ3分のような何か、17ついている。 何でも漏ればタイヤの圧縮機は破壊、うまく行けばyou'に動く; dはそれを聞く。 you'なら; veはあなたがどちらかの苦境をECAS (google厚木ECASか。)必要とする高さセンサーを得たまたは新しいシステムを造りなさい。 That' s場合のI' Gliderite/Driveriteへのdの話はまたはある鋼鉄ばねを捜すことを行く。私およびI'システムmail/pmを設計することにすれば; llは設計図し、自動車ディストリビューターが確認するかもしれないある部品番号。これのための部品は終わる£200に動く。 ECASセンサーはmuchnessの多くである、従ってどの12V圧縮機の単位でも働くことができる。 Range RoverまたはBMWの単位は行っているあなたyou'を得るかもしれない; you'の前にその特定項目のための配線図を見つけるdの必要性; dはそれに、水平それ等動力を与える方法を知っている。 私は単位を見つけることができたらI' WABCOの単位のための図表を得てもよい; 空気の苦境を推測するmはより簡単である。 I' dはScattergoodおよびJohnsonsまたはThoriteのabouts、一種のような誰かに圧縮機リングをの気体力学の下のイエロー・ページのディストリビューターここに持って行く。 It' s.aの勝つ見込みの低い参加者しかし誰か他の人は同じ事を使用するかもしれない。
This is Andy M's reply translated into Japanese (via Babel Fish) and it made almost as much sense to me. Am I really that thick*?
I'm supposed to be meeting AndyD at Cadwell in two weeks time for the first round of SuperMono racing. He, and the precious cargo, could have a very bumpy journey if his bodge fails; we are becoming Team Araldite in so many ways........
* as in intelligence not width!
« Reply #18 on: April 29, 2009, 07:13:31 PM »
Wow. I used to be able do a little cantonese, but that's impressive  ;D
The old compressor will indeed be exhausted (It's a pneumatic joke!). The duty cycle is about 20% 5 min ED, or 1 minute on 4 off in english.
