Author Topic: szr660  (Read 8167 times)
chippy
szr660
« on: March 17, 2009, 06:26:16 PM »
I am having problems with the starter on a 660,sometimes it spins the motor,sometimes just the starter spins and ocaisionally it makes a grinding sound.
 I have pulled the side cover off to expose the sprag clutch and the crank pinion can be moved in and out,is this normal?
 Is the nut on the end of the crank rh thread?
 Can anyone point me in the direction of some reading on this side of the engine and troubleshooting.
 Any help/advice would be much appreciated
 Thanks Gary
Re: szr660
« Reply #1 on: March 17, 2009, 08:52:43 PM »
Aye chippy,
Go to this site and download the 2 pdf files which are toward the bottom left of the page, you'll find them. :)
http://motorbikemanuals.blogspot.com/2008/07/yamaha-szr660-service-manual.html
Also try searching Google with 'Yamaha SZR 660', also keep coming back here, all sorts! :-X
I hope you get it sorted
Regards, Bill.
chippy
Re: szr660
« Reply #2 on: March 17, 2009, 09:58:41 PM »
I couldnt get the thing to download,I am not too hot on computers ! if it does not work I am stumped!!
I have a service book tha I downloaded but it does not tell you any faults or play etc.
As I see it the pinion on the crank spins freely one way ,then bites when it is turned in the opposite direction,But the pinion can be moved in and out so that it does not always mesh,so I was looking for pointers as to the fault,there is only one chipped tooth on the pinion and everything looks in good order to me.
  Thanks Gary
Re: szr660
« Reply #3 on: March 18, 2009, 12:10:08 AM »
Aye chippy,
Sorry about the duff URL. >:(
I've just tried this one, which works. Give it time, it's a big file ~15Mgb! ;)
http://www.carlsalter.com/aaman/Yamaha_SZR_660_'95_service_manual.pdf
Regards, Bill.
Re: szr660
« Reply #4 on: March 18, 2009, 07:32:20 AM »
Hasn't SteveH got and szr?? ....he knows EVERYTHING! :-)
Re: szr660
« Reply #5 on: March 18, 2009, 07:53:10 AM »
No I havent, and no I dont
« Last Edit: March 18, 2009, 11:18:07 AM by Steve H »
chippy
Re: szr660
« Reply #6 on: March 18, 2009, 04:50:56 PM »
Thanks,I managed that one,now to see if I can understand
 Gary
Re: szr660
« Reply #7 on: March 18, 2009, 11:53:14 PM »
Aye Garry,
Pleased you got that to download OK. I hope you have been able to trace the problem.
chippy
Re: szr660
« Reply #8 on: March 25, 2009, 10:04:43 PM »
I got the nut off the end of the crank,then came the hard bit!
I made a puller out of 3/8 plate and some 8mm studding,then put a small jack between the end of the crank and the plate and jacked,this did not move the rotor.
Anyone got a wand for hire?
Re: szr660
« Reply #9 on: March 25, 2009, 11:35:31 PM »
Aye Garry,
Make sure your puller is all on square and then apply the pressure so that everything is under tension but not deforming! :o Now take a 2lb ball pein and sharply smack the end of the puller so as to 'shock' load the puller. The whole lot should fall off with a loud bang and clatter, so have a towel ready to cushion the fall.
SteveL, SteveH or Jethro may have their own ideas as well, mine is not without risk. ???
However, after putting a Duke single, crank under 28 tonnes of pressure to part it :o that really went off with a bang! ;D
Keep us posted and remember, somebody may have used Loctite or Locnut on the taper. ???
Re: szr660
« Reply #10 on: March 26, 2009, 07:41:29 AM »
In the past Ive used an air impact hammer to drive the puller, took a while but it eventually came off without too much drama. 12v impact hammers can be bought from screwfix etc if you dont have a compressor
Re: szr660
« Reply #11 on: March 26, 2009, 10:25:05 AM »
Get it square, nip it up tight, give it a whack, nip it up tight, give it a whack etc
Oh and then discover another fixing you did not see and the whole lot is toast (dont ask me how I know)
However I do have a flywheel stuck on a crank (old JAP rotovator engine..  Cannot shift it despite all best efforts and those of the local garage and their hydrolic press.  I think there has been some electrolytic corrosion between the flywheel (ally) and the crank (Steel).  Motor never appears to have run, so I am guessing that the flywheel is 180° out
chippy
Re: szr660
« Reply #12 on: March 26, 2009, 12:35:36 PM »
I have bought a puller to try the tighten/whack procedure,first attempt was non effective!
Inside the rotor are three 8mm tapped holes to fasten the puller to,there are also three allenheads showing,the book makes no mention of removing these,do they hold the two steel discs onto the back of the rotor?
Do all these parts come away as one? It looks like it in the book.
When I get further on I am looking forward to the reassembly is a reversal of dismantling page.
Thanks for the tips I will post the progress.
  Cheers Gary
Re: szr660
« Reply #13 on: March 26, 2009, 11:15:33 PM »
Aye Garry,
I haven't been into the guts of the MZ on the alternator side, but from looking at the manual and reading your queries, my inclination is:
  Cheers Gary
It is the repeated nip/whack technique which eventually parts the tapers, the retaining nut's torque of 110ft/lbs exerts a very strong loading, you may also find that the woodruff key in the crankshaft wasn't properly aligned during assembly and this may also be increasing the 'grip' of the taper. You may also carefully apply heat from a hair dryer or a hot air paintstripping gun to the rotor alone, around the taper. This may allow suficient expansion to ease the grip of the taper. I wouldn't use a bare flame and keep the heat away from the crank. You don't want to loose the magnetism within the rotor, by using to much heat.
"Inside the rotor are three 8mm tapped holes to fasten the puller to,there are also three allenheads showing,the book makes no mention of removing these,do they hold the two steel discs onto the back of the rotor?"
On page 4-75, Section G3, Allen head set screw requires loctite when rebuilding, but cannot see any need to remove whilst the whole AC rotor assembly is on the end of the crankshaft. I would er not to. Yes, they appear to retain the disc within which the starter clutch is held.
"Do all these parts come away as one? It looks like it in the book." I would agree with your assumption, but it is an assumption :-\
"When I get further on I am looking forward to the reassembly is a reversal of dismantling page." Page 4-75, Section G3, would appear to answer your questions.
Hope this helps, Bill.
chippy
Re: szr660
« Reply #14 on: March 27, 2009, 10:12:22 PM »
Just gave in on the tighten/wack system!
The new puller bent,we used a battery impact driver(heavy duty) and it bent the puller(clarkes)
I even wore my specs,it has been attempted before i think ,there is a "divot" in the rotor cntre where it looks as if someone has had acetylene on it.
I am now in need of a plan J
If I can borrow the yamaha tool for the job would it be stronger than the clarke thing.
 How easy to find are all these parts ,if they have to be chopped off?
 Thanks  Gary
