Author Topic: Try this  (Read 1591 times)
Try this
« on: October 17, 2008, 11:48:08 AM »
http://www.forddoctorsdts.com/quizzes/MechanicalAptitude.php
At the end, by clicking on the magnifying glass, you can review which (if any) you got wrong.
Dave#22
Re: Try this
« Reply #1 on: October 17, 2008, 09:49:37 PM »
I got 88%, and #48 wrong, but if it's atmospheric pressure that fills a cylinder, how do you generate a vacuum to make a carb work......eh?
    Dave
Re: Try this
« Reply #2 on: October 17, 2008, 10:16:27 PM »
Seeing as this could get competitive - 92% or 460 points.
I ballsed up the following and didn't cheat at all.
Q7 (drive ratio type)
Q16 (pulleys)
Q25 (electrical)
Q48 (bollocks, I still think I'm right and they're wrong)
Hehehehe..............that was fun.
Re: Try this
« Reply #3 on: October 17, 2008, 10:29:43 PM »
I managed 84%.
Started to gey bored and rushed some !!!!!!
pigafetta
Re: Try this
« Reply #4 on: October 17, 2008, 10:59:10 PM »
I passed...just.
I forgot to look at the ones I got wrong though ::)
Dave
Re: Try this
« Reply #5 on: October 18, 2008, 07:21:21 AM »
    Dave
Some of the questions are a bit ambiguous. It is atmospheric pressure that filles a cylinder but only because the falling pistons causes a vacumm, the pressure differential causing teh air flow. So the answer ' the air is sucked in' could be considered correct as well, just not technically accurate.
Carbs dont rely on a vacuum in the cylinder they rely on the venturi effect. The vacumm in the cylinder just causes the air to flow from outside to in
http://en.wikipedia.org/wiki/Venturi_effect
Re: Try this
« Reply #6 on: October 18, 2008, 10:19:28 AM »
mmmm 92%, but i question the one about the fan......yes it will turn in the same direction facing each other, but, if say, the fan that is running is turning clockwise to produce a draft, then the unpowered fand will be forced to turn anticlockwise......or am i talking out of my ar5e?
pigafetta
Re: Try this
« Reply #7 on: October 18, 2008, 10:35:32 AM »
The unpowered fan will turn anticlockwise if the powered fan is turning clockwise.
I got the suction/atmospheric pressure one wrong too. Isn't 'creating a vacuum' just another way of saying 'suction'? Without the vacuum, atmospheric pressure wouldn't fill the cylinder.
Dave
Re: Try this
« Reply #8 on: October 18, 2008, 11:19:51 AM »
I'd agree with you about the fan. I'm going to test it in work on monday
guest40
Re: Try this
« Reply #9 on: October 18, 2008, 12:32:34 PM »
This sort of thing beats my jokes any day
love it
I passed!!
Re: Try this
« Reply #10 on: October 18, 2008, 07:43:08 PM »
i got 80%, i know the questions with the pulleys foxed me.
i was confused on a couple, and it would seem i'm owed points on the fan question and the induction question.
it seemed fairly typical that i just scraped a 'pass'. use the absolute minimum of brain power required to complete a task sucessfully!
Re: Try this
« Reply #11 on: October 19, 2008, 02:12:35 PM »
Mmmmmm !  Me Too !  Started to get bored me.
