Author Topic: Vibration  (Read 3738 times)
Happy Daze
Vibration
« on: June 17, 2008, 07:34:23 PM »
What levels of vibration can i expect at the bars on an sr 500 with a good amount of throttle? Say on a scale of 0 to a cordless drill on hammer or beyond.
guest288
Re: Vibration
« Reply #1 on: June 17, 2008, 08:24:47 PM »
If you're suffering with severe vibration in the bars, you may want to have a play around with bar end weights...
Happy Daze
Re: Vibration
« Reply #2 on: June 18, 2008, 06:48:55 PM »
Thanks,it never even occurred when i threw the originals away. I'm not even sure if there was any. What sort of weight would be a starter?
guest288
Re: Vibration
« Reply #3 on: June 18, 2008, 07:10:40 PM »
To be honest, I'm not really sure- maybe somebody else has an idea?
Maybe you could try and find the origininal part number and trace the original weight value from there?
guest288
Re: Vibration
« Reply #4 on: June 19, 2008, 04:02:16 PM »
I asked on another forum and they said to experiment with weight- they also thought the bars should be rubber mounted so maybe the bushes need looking at? Also they mentioned about the possibility of anti vibration grips. One other guy said he didn't bother with weights at all!
Happy Daze
Re: Vibration
« Reply #5 on: June 19, 2008, 05:16:13 PM »
Thanks, i'll have a go at the weights. the mounts are ok and the engine sounds good, so a bit of trial and error seems to be in order.
Re: Vibration
« Reply #6 on: June 19, 2008, 06:48:55 PM »
 bsa had some grips that were designed to cut vibration on A65's (cheaper than building them properly i suppose).
 i fitted some to my enfield and it helped. they're quite 'chubby' and sort of barrell shaped. if you ask at a brit bike shop for bsa a65 type grips they'll know, i think mine were ten quid.
Happy Daze
Re: Vibration
« Reply #7 on: June 20, 2008, 03:08:49 PM »
Thanks, I'll try e-bay or something, you really have to whisper the "Brit" word over here, and I don't know of a single shop.
