Author Topic: Purging butane cylinders  (Read 1823 times)
« on: June 02, 2008, 10:23:49 AM »
I have a couple of non-standard butane cylinders that I think I will struggle to swap for Calor ones, not to worry I want to use one as a res for a vacuum pump.
Does the valve just thread into thte top?  how do I purge the residual gas - water. carbon monoxiode or just throw a match at it.. he he he
Any ideas on the thread form if it is threaded
Any thoughts on a manual valve for it ?
Thanks
Re: Purging butane cylinders
« Reply #1 on: June 02, 2008, 10:55:37 AM »
I just fill them with water, to the brim, and drain them off.  Then I attak them with angle grinders.
« Reply #2 on: June 02, 2008, 06:27:22 PM »
Perfect - thanks.
« Reply #3 on: June 03, 2008, 07:21:50 AM »
youd be better purging with nitrogen than using water. theres no way of removing the residual water from the inside of the tank and then vac it out. (steel tank?)
« Reply #4 on: June 03, 2008, 01:41:11 PM »
Yup - steel tanks.
No nitrogen - cept in the atmosphere but I have a source of air with all  the oxygen removed - car exhaust.  Mind if the water proves to be a problem I guess I can put the tank on the bonfire for a bit - having purged it and removed the top....
« Reply #5 on: June 03, 2008, 09:01:16 PM »
Drop in some dessicant bags? iirc you find them in new trainers, could maybe blag some free from a shoe shop if you pass one?
edited to add, I mean for getting rid of the water not the gas!!
Jez F
« Reply #6 on: June 05, 2008, 07:34:08 AM »
As Butane and Propane are both heavier than air, why not remove the valve( make sure it's empty first!!) and stand it upside down, a few inches off the ground outside for a couple of days, should save messing around with water and having to dry it out.
 Jez
