Author Topic: help srx footrest  (Read 3065 times)
bebo
help srx footrest
« on: May 30, 2008, 03:41:25 PM »
Hello to all. I am umberto of naples (italy) and try the footrest as arrears in these photos x yamaha srx 1xl of 1986.
You know who manufactures them and maybe the cost?
x compliments the bike through pictures, very beautiful.
thanks to all
http://www.thumperclub.com/photos/2007/thumper467fa4b387020.jpg
Re: help srx footrest
« Reply #1 on: May 30, 2008, 07:44:17 PM »
Bebo saluti,
Sto usando la lingua di Google strumenti per cercare di rendere questo più facile per gli utenti a leggere!
La moto sembra appartenere a SteveL e credo che la rearset poggiapiedi sono state effettuate da Raask. Ho il sospetto che SteveL presto dirmi se sono corretti su questo. Spero che la traduzione si legge bene.
I miei saluti, Bill.
Greetings Bebo,
I am using the Google language tools to try and make this easier for you to read!
The bike appears to belong to SteveL and I think the rearset footrests were made by Raask. I suspect that SteveL will soon tell me whether I am correct about this. I hope the translation reads well.
bebo
« Reply #2 on: May 31, 2008, 10:01:20 AM »
thank you! ok, I also do the translation with google.  ;D
then look for news footrest .
lamps
« Reply #3 on: June 01, 2008, 12:33:19 AM »
Hi Bebo....and welcome
Yes, they are my footrests you see
I'm afraid Bill was wrong this time (not often that he is  :D )
I bought the footrests off Ebay, and i think they are from a Kawasaki Z750 or something similar)
I made the backplates up myself, then stripped the kawasaki rearsets and fitted them to my backplates (with a few modifications).... using the original srx rear brake master cylinder (the brake fluid entry had to be modified.... and i used a new braided hose, made up to suit the new position of the master cylinder)
I could make up the backplates for you..... you would need to find some rearsets to do the whole job
then you can drill the back plates to suit the footrests that you buy.
« Reply #4 on: June 01, 2008, 02:16:36 PM »
Bebo saluti,
:-[ Win alcuni, alcuni sciolti ::)
Bebo mio scuso per fuorviante. Tuttavia, che appare molto poggiapiedi Raask simili.
Forse dovrei andare via e succhiare su di esso come un rusk bambini? :-X
Speranza di poter effettuare o di acquisto di una serie di rearsets a proprio piacimento.
 :-[ Win some, loose some ::)
My apologise Bebo for misleading you. However, that footrest looks very Raask like.
Maybe I should go away and suck on it like a babies rusk? :-X
Hope you can make or purchase a set of rearsets to your liking.
« Reply #5 on: June 01, 2008, 10:21:50 PM »
Yes they do Bill.....maybe they use the same footpegs?......dunno.....you were close though :-)
« Reply #6 on: June 02, 2008, 03:40:39 PM »
Hi,
I have some rough blanks you can have/ fix/ modify if you are handy.  Not quite finishsed but you may be able to use them....
Photo--->
and the other side:
If the photos dont work they are:
http://www.thumperclub.com/displayphoto.php?&index=107&set=projectsgallery2&menu=Photographs&direction=r
and the other side:
http://www.thumperclub.com/displayphoto.php?index=106&set=projectsgallery2&menu=Photographs&direction=r
Or have a look round www.team-thumper.wetpaint.com
You will have to make a mount to re-use the rear brake master cylinder.
Can send you pics of the blanks if you like?  They are not perfect, but usable?
andy
