Author Topic: srx 400 mono shock forks  (Read 2310 times)
turpitz764
« on: April 13, 2008, 04:48:48 PM »
hi could anyone tell me if the srx4 monoshock forks and yokes will fit the older twin shock srx 4...?
Re: srx 400 mono shock forks
« Reply #1 on: April 13, 2008, 06:33:25 PM »
They fit but the lockstops are different. The existing ons will need to be cut off and new ones welded on. You will also need to use the mono front wheel/brakes, unless you have a late 400 twinshock, in which case you might get away with spacers
turpitz764
« Reply #2 on: April 14, 2008, 10:37:48 AM »
thanks for that...i have another question do the 600 forks fit straight on?...im asking this because my 400 has twin discs so im presuming the forks are from a 600 and they need replacing.  just want to keep my options open.
« Reply #3 on: April 14, 2008, 11:42:45 AM »
I believe the later 400's had twin discs as standard. The 600 twinshock forks are dimensionally the same as the 400. The main difference is between import and UK forks, the imports have fork caps with valves, the UK bikes dont.
