Author Topic: Coils - not a problem as such  (Read 3134 times)
« on: March 18, 2008, 05:28:42 PM »
There I was in the pouring rain on the stag do and the Bonneville developed it's ***ing misfire again  >:(
WD40 everything electrical and it's good for the 100 miles home. Once in the dry I greased and tightened and cleaned and it'll be good until some downpour next winter. However, aiming for a long term cure I borrowed a nice sealed chinese made coil off a lad at work (Kawasaki twin) with the aim of moving it under the seat where the battery used to be. This coil while it idles just fine gets a missfire at higher revs  :-\
So, it looks like it's back to trying to seal the Triumph coil  ???
The question then is how to tell a sealed coil that will work (right resistance?) from one that won't  ???
Good news is I picked up a spare Triumph one off e-bay, so if it is the coil rather than the wiring that's the pain in the **** i'll find it/cure it in one go  :)
Re: Coils - not a problem as such
« Reply #1 on: March 20, 2008, 04:22:58 PM »
Misfire - nah mate they all do that - it is called charecter.
« Reply #2 on: March 21, 2008, 07:48:17 AM »
Did you ever work for BMW?  ;D
