Author Topic: CX/RS front disc??  (Read 523 times)
CX/RS front disc??
« on: June 08, 2026, 07:49:39 AM »
I’ve “heard” that the Honda CX front disc is a direct swap for a Honda Cb250rs. Does anyone out there know if this is correct?
I realise the CX disc is slightly larger in diameter but I intend to swap the front caliper too, so diameter isn’t an issue. It was more the stud pattern/centres
Thanks… Michael
Re: CX/RS front disc??
« Reply #1 on: August 23, 2026, 06:27:48 PM »
In terms of bolt spacings, any honda with comstar wheels will have the same pattern, so superdreams, cx500 and even cb650/750/900. Whether the diameter and offset suit I can't say, but I know comstar wheels disks fit an rs hub cos I've done it albeit years. Ago.
« Reply #2 on: August 24, 2026, 08:52:18 AM »
I think I have a CB250RS disc lying about somewhere if it's any use to you? Yours for postage and a pint.
« Reply #3 on: August 24, 2026, 03:22:02 PM »
Many thanks for the offer Ian, however I also have an RS250 disc but I’m “upgrading” the front brake on the “different tracker” project bike. I’ve since found out that, yes the CX Eurosport front disc is a direct swap for the smaller original RS disc.
The CX disc being a larger diameter. So going for an EBC stainless replacement, along with a Royal Enfield scram master cylinder/lever and front caliper.
All that braking power….. I’ll be pulling stoppies at every set of traffic lights I come to 😁😉
« Last Edit: August 24, 2026, 03:25:44 PM by Moto63 »
« Reply #4 on: August 27, 2026, 06:08:36 PM »
Just to let you know. The Honda cx Eurosport front disc IS a direct bolt on swap for the original cb250rs disc.
I’m not sure it goes on with the original caliper in place with it being a slightly larger diameter. I’ve had a plate milled up to accommodate a twin piston Royal Enfield scram front caliper
Cheers… Michael
