Author Topic: srx600 top end clicking  (Read 8338 times)
srx ijk
  • Newbie
« on: September 03, 2025, 06:04:14 PM »
Hi all - my srx600 is now starting well and pulling strongly, but.... I have a top end noise which sounds just like bad tappet clearances but isn't (checked twice and clearances spot on).
Thoughts please on whether this could be piston slap or a cam chain/tensioner problem (both seem unlikely on a relatively low miles engine and the noise persists even when engine warmed up).
Anybody else had this problem?
thanks
Glyn
Re: srx600 top end clicking
« Reply #1 on: September 24, 2025, 06:50:50 AM »
Check that the decompressor lever isnt touching the rocker arm. Run the engine and hold the decompressor lever, if its moving then the cable needs adjusting.
Piston slap will be more evident when cold and clear when hot, if its bad you may hear it on part throttle when warm. Generally tends to be a lower frequency than tappet noise.
I would expect tensioner problems to result in a russling noise.
Rev counter cable could be another source if its damaged.
Exhaust gasket leaking ?
srx ijk
  • Newbie
« Reply #2 on: October 18, 2025, 06:09:28 PM »
Hi Steve - just come across your reply - will check your recommendations. Many thanks!
srx ijk
  • Newbie
« Reply #3 on: October 28, 2025, 03:42:16 PM »
Update - so with the engine running the decompressor lever doesn't move (but will oscillate backwards and forwards when pushed back against the cam), rev counter cable seems fine, exhaust stud nuts tight.
Agree with you re camchain rustling noise - it's not a constant noise - more like a tapping.
I'm beginning to think it's got to be piston slap (not audible at all when riding 20 mph or faster, but exactly same sound when stationary with engine cold or hot & at all engine speeds).
Also only became evident after over-wintering in the shed on first start up - and oddly not present at all last Autumn before hibernation.
I think it's head off time!
« Reply #4 on: November 11, 2025, 09:56:10 AM »
I would have described piston slap more as a 'clack' rather than a 'click'.
What exhaust are you running ? if its the original steel item has a rust pinhole developed over the winter ?
« Reply #5 on: November 11, 2025, 02:10:11 PM »
In my experience piston slap is worst when the engine is cold, and tends to be when it's lightly loaded rather than open throttle. But noises are so hard to isolate! I've always run my obsolete old clunkers with what used to be known as "racing clearances" ie nearly worn out. My ES2 had quite loud piston slap when cold but didn't burn any oil and went like the clappers.
srx ijk
  • Newbie
« Reply #6 on: November 15, 2025, 12:16:30 PM »
Update and conclusion- took off the valve cover, had a careful look over and could see nothing amiss.
Decided against taking the head off, reassembled, reset valve clearances again....wouldn't start (doh).
Revisited the valve decompressor cable free play (should be 3 to 5mm) and readjusted (didn't realise it had to be set with piston at TDC on compression stroke), started first kick and clacking noise gone!
So still not sure/can't remember adjusting the cable previously, but obviously this was the source of my noise. Only about 4 hours abortive work and 10mins to fix.
Thanks very much to Ian and Steve for their guidance/suggestions.
Glyn
« Reply #7 on: November 17, 2025, 04:54:37 PM »
Good to hear you have it sorted
