Author Topic: A different tracker frame question?.  (Read 4483 times)
« on: June 02, 2025, 11:08:35 AM »
Hopefully someone out there in TC can help me sort out a problem I’m having with a frame I’ve got.
I only have a frame number to hand, no reg number. Does anyone know of a way to find out if/when. The bike/frame was registered, or find out what the actual reg number was just from the frame number?.
Any advice would be most appreciated
Re: A different tracker frame question?.
« Reply #1 on: June 02, 2025, 11:47:37 AM »
The Honda Owners Club may have that info, although I suspect the original number will have been lost. Or you could re-register with an age-related number. If you go that way you need to have a more or less complete bike with engine and frame number relating to a similar year/ model. Again, the owners club - or maybe the VJMC - may be able to help.
I did this last year for my Tri-Greeves which I assembled as a Greeves, got the riders' association chap to validate it then sent off all the suff to DVLA. It was fairly straightforward. And of course if your frame is pre-1984 or so then it will be free road tax and no MoT required.
« Reply #2 on: June 02, 2025, 12:34:31 PM »
Many thanks for the info Ian. I’ll try the Honda owners club first, see if they can turn anything up🤞
I’ve taken a punt on an engine off fleabay 🤞🤞
So once that arrives I will have an engine and frame number, so as a last resort I can go down the route and try, as you’ve suggested to re- registering it 🤞
« Reply #3 on: June 02, 2025, 07:11:22 PM »
You could also try the VJMC Michael.
