Morning Oldtimer,
Goldie in a Featherbed has to be up there with the Duke for producing
! It needs to be out and about.
I can provide part numbers etc, but just need to clarify that the carb is an Amal Concentric MKII and if so, what actual size the the bore is? Has the motor been ported and gas flowed or has it a standard head?
A 'Stay-up' float etc are all available 'off the shelf'.
Here is the link to the Amal MKII 2000 Series home site:
MKII-Concentric-series/2000-seriesDrop the float bowl and see if it is full of crud. Ruddy ethanol fuel/condensation soon corrodes the aluminium alloy (MKI's are zinc alloy), so keep it drained, unless in use. Be warned that sonic baths don't always cope with the corrosion and the small drillings in the carb body can become blocked, rendering the instrument useless!
I have cleaned carbs using an orbital sander to provide the agitation, but it is a messy and vexing job requiring patience and an air compressor as well!
All the best, Bill
