Author Topic: fierce brake  (Read 1033 times)
fierce brake
« on: June 13, 2019, 09:31:04 PM »
I have a little 125cc two stroke (gilera) with a really good brembo disc on the front, in fact it is too good, is there any way to make it a little less fierce ? it can lock up very easily on damp surfaces and at the minute that`s all we have up here, i haven`t had a chance to try it on dry roads yet,
Re: fierce brake
« Reply #1 on: June 13, 2019, 11:42:21 PM »
Aye Rufus,
Organic pads rather than metallic pads, or one of each in the caliper. This is a suggestion, not a recommendation! ;)
When you go scratching with it, you may wish to revert to metallic pads both sides?
Re: fierce brake
« Reply #2 on: June 14, 2019, 07:13:10 AM »
Spooks... I can't believe you've overlooked the obvious. Just spray plenty of WD40 onto the disc face. Defo be less fierce then 🤣🤣🤣🤣
Ps... I AM JOKING
Re: fierce brake
« Reply #3 on: June 14, 2019, 10:17:37 AM »
Ps... I AM JOKING
Transfers the squealing from brake to rider 😂😂😂😮
Re: fierce brake
« Reply #4 on: June 14, 2019, 03:15:42 PM »
well i think i was  worrying about nothing, on dry roads its fine, maybe i`m just used to crap brakes... thanks  everyone, I may try some of those orgasmic pads bill...  ;D
Re: fierce brake
« Reply #5 on: June 15, 2019, 09:12:07 AM »
Those will be the blue, diamond-shaped pads - tricky to get hold of, but strong performance and a great feel at the lever guaranteed!  ;D
Re: fierce brake
« Reply #6 on: June 17, 2019, 09:06:40 PM »
whats your tyre like? it may be that the wheel locks easily because the tyre lacks grip? try fitting something stickier to it if its an old tyre.
