Author Topic: Srx600 blowing indicator bulbs  (Read 517 times)
Danxup
  • New Member
« on: February 09, 2019, 08:53:16 AM »
Ey up chaps.. My 600 is doing at least one if not 2 somtimes 3 indicator bulbs evry time i go out.. Anyone had this befor?
Re: Srx600 blowing indicator bulbs
« Reply #1 on: February 09, 2019, 09:41:54 AM »
It being a big single, could be loose connection/vibrations at the lamp holder. Or water getting in. Or a short on that circuit. Or cheap/ wrong wattage bulbs or fingerprints on the glass overheating it. Best of luck.
« Reply #2 on: February 09, 2019, 10:44:19 AM »
Aye Dan,
Agree with mthee.
Sally had phases of repeatedly blowing random indicator bulbs. Cheap Chinese bulbs and intermittent electrical feed appeared to be the causes (corrosion and worn insulation). I chose to buy heavy duty (HD) filament bulbs and replace the original indicators with rubber stemmed 'shorty' indicators from Vehicle Wiring Products (VWP) (Link:Vehicle_Wiring_Products) and new wiring/connectors from the loom. This appeared to resolve the problem. Fitting L.E.D. indicators/bulbs would also take away the 'flaky filament' weakness of bulbs and give 'brighter' indicators, but would require the fitment of a suitable flasher unit.
Take your pick. I hope this helps
« Last Edit: February 09, 2019, 06:48:37 PM by themoudie »
Danxup
  • New Member
« Reply #3 on: February 09, 2019, 12:12:15 PM »
Thanks fellas ill let you know how i get on..
