Author Topic: Honda XL500 carb spacer  (Read 650 times)
tevie54
« on: November 08, 2018, 09:37:45 PM »
Hi, Does anyone know what the phenolic spacer that goes between the carburettor inlet rubber and the cylinder head does, do I need it? I'm fitting an XL500 engine to my XL250 so obviously there will be a certain amount of modification needed but I'm just wondering what this spacer does.
Any info would be greatly appreciated
Steve
Re: Honda XL500 carb spacer
« Reply #1 on: November 08, 2018, 09:43:02 PM »
A heat break I'd guess
tevie54
« Reply #2 on: November 08, 2018, 09:52:11 PM »
It could be although the 250 doesn't have one
« Reply #3 on: November 09, 2018, 12:03:33 AM »
500s ran hot. they had a problem when they were really hot of fueel evaporating in the carb causing uneven running.
tevie54
« Reply #4 on: November 09, 2018, 01:21:02 PM »
Of course, when I googled phenolic spacer it immediately came up with heat insulator. They're no longer available from Honda and they're quite expensive second hand so I wonder if I could make one out of nylon or tufnell
« Reply #5 on: November 09, 2018, 09:48:06 PM »
Aye tevie,
Nylon 6.6 sheet [-40˚F to +390˚F (-40˚C to +199˚C)] has better heat resistance than either Tufnol [Continuous = 90°C, intermittent = 125°C] or Nylon 6 sheet [Continuous = 115°C, Intermittent = 170°C].
Amal supply Tufnol spacers for Monobloc and MKI and MKI½ that are 5mm thick, but I suspect are too small a diameter bore (26mm) for the inlet you have and cost £11-99 inc VAT + P&P. Amal_Tufnol_spacer_26mm
Alternative would be to use nylon 6.6 sheet. Direct Plastics supply (many other suppliers, I have not bought from this or other suppliers) Direct_Plastics_nylon6.6_sheet_6mm_thick
Another possibility is to buy a spacer from NRP-Carbs, they also supply diaphragm kits for carbs and their products are good. NRP-Carbs_XL500_carb_spacer
Hope this helps.
« Reply #6 on: November 10, 2018, 10:10:44 AM »
Morning Bill, as usual your knowledge of part suppliers astounds me. I certainly know who to ask shud I ever require that elusive part..... you da maaan 👍👍👍😁🤘
« Reply #7 on: November 10, 2018, 11:55:33 AM »
i suppose you could buy a chunk of bakelite and get busy with the files and emery paper.
tevie54
« Reply #8 on: November 10, 2018, 04:53:17 PM »
Thank you all for the information, I think I shall be making one out of 1/4 nylon. I have something in the shed that looks awfully like one so I'm wondering if I've previously experimented with carb spacing on the 500RS
