Author Topic: Xbr missing  (Read 3849 times)
Mutt
  • XBR500
Re: Xbr missing
« Reply #15 on: October 22, 2018, 02:50:19 PM »
Mine is 42k. Managed to get out yesterday having swapped the tank from my build bike just to have a comparison. After a few warming up miles no issues with 1st, 2nd, 3rd going to the red line and 4th almost; 5th revs through the 4k without issue but got the issue at 5k but it rode through. Back to home and found that the starter motor had decided to just make 'clicking' noises - the joys of classics - so just as well it has the kicker! Fuel tap and filter in tank has been duly cleaned (no sign of crud in tank) and I'll be taking it for longer runs next week, hopefully, to see how things are. If all else fails I'll get the carb out and borrow friends ultrasonic bath* again.
*I'm told that those foot spa's are similar but we chucked ours some time ago!
Regards, Clive.
tevie54
Re: Xbr missing
« Reply #16 on: November 08, 2018, 09:50:22 PM »
Check the fuel tap is flowing the correct amount of fuel, I had a similar problem on the RS500 , bigger carb but standard fuel tap so not flowing enough fuel to fill the float bowl at high RPM so would misfire. If you've got a blockage or restriction it might do the same thing.
Mutt
  • XBR500
Re: Xbr missing
« Reply #17 on: December 03, 2018, 10:57:40 AM »
My update, having taken a tad longer than planned, is that the 'clicking noise' was resolved with a new battery (old one had died) and the ultrasonic bath worked its magic on the carb and the bike now revs through easily with no issues at any RPM. Hopefully Clubman44 has managed to get sorted too.
Regards, Clive.
Re: Xbr missing
« Reply #18 on: December 03, 2018, 04:48:52 PM »
Pleased to read that the simple diagnostics have proved correct and all now appears well. Happy miles.  ;D
Go canny, Bill
Clubman44
Re: Xbr missing
« Reply #19 on: March 20, 2019, 08:52:26 PM »
Just a little update I fitted a new Honda coil, and a iridium plug but there’s no improvement it’s still hesitating at 4 to 4500 rpm in 4 and 5 gear not sur where to go, maybe a run on a rolling road might turn up something.
Re: Xbr missing
« Reply #20 on: March 21, 2019, 07:41:03 PM »
Just a little update I fitted a new Honda coil, and a iridium plug but there’s no improvement it’s still hesitating at 4 to 4500 rpm in 4 and 5 gear not sur where to go, maybe a run on a rolling road might turn up something. Sounds like a good idea. Keep us posted.
Tony500
Re: Xbr missing
« Reply #21 on: March 30, 2019, 01:59:33 PM »
I had exactly the same problem. Dirt from the fuel tank was blocking up the carb.
It was a bit fiddly to get the carb completely free of dirt and little shards of metal, which probably came from the inside lining of the fuel tank. If you take your fuel tank off and shake it a little bit can you here sludge moving around?
I ended up getting a fuel tank from eBay which was thankfully in better condition than the original.
If you get stuck I should have a spare carb lying around that I could post (and loan) you.
Good luck.
Clubman44
Re: Xbr missing
« Reply #22 on: April 02, 2019, 08:56:17 PM »
Thanks for the offer Tony, I have got the bike booked in this Saturday on the rolling road, should know a bit more after that.
Regards Rod.
Clubman44
Re: Xbr missing
« Reply #23 on: June 14, 2019, 12:35:13 AM »
Sorry for not coming back earlier however I wanted to be sure the problem had gone away. On the Dyno the bike performed faultlessly He. Couldn’t find anything wrong with it, I was very sceptical, however I rode it home and it seemed fine I have been using it since with no repeat of the problem. I can only assume it was some kind of carb blockage, that cleared when the bike was put under a heavy load on the dyno
Regards Rod.
Re: Xbr missing
« Reply #24 on: June 15, 2019, 09:25:28 AM »
Thanks for posting your conclusion. Nothing worse than getting to the end of a thread like this and finding it unresolved.
Re: Xbr missing
« Reply #25 on: June 15, 2019, 11:34:09 AM »
What were the readings? Power/torque.
Clubman44
Re: Xbr missing
« Reply #26 on: June 15, 2019, 08:46:30 PM »
Will try and find the read out and let you know although from memory it was about 32 at the back wheel.
Re: Xbr missing
« Reply #27 on: June 16, 2019, 07:08:19 AM »
Cheers. Just curious, as others will be I imagine.
Re: Xbr missing
« Reply #28 on: June 16, 2019, 12:49:42 PM »
Definitely! Good question. :)
Re: Xbr missing
« Reply #29 on: June 16, 2019, 01:03:24 PM »
Trust me, he's full of em. (Good questions that is 😁😁)
