XBR SEAT LOCK WON'T DISENGAGE
3
Topic: XBR SEAT LOCK WON'T DISENGAGE (Read 2011 times)
January 27, 2018, 06:23:09 PM »
As my bike hasn't turned a wheel since i put it in the garage at our new house on 23rd of December i decided to charge up the battery but i can't access it as the key doesn't turn fully in the lock so the seat can't be removed. They are never a good fit in my experience but is was working last time i used it which could have been several months ago now.Any ideas please on how to the seat off?
Re: XBR SEAT LOCK WON'T DISENGAGE
January 27, 2018, 11:41:31 PM »
Aye xbally,
Soak the lock in PlusGas-A or a similar releasing oil, give it at least 24 hours to soak and the apply more and gently wiggle the key in the lock!
All the best, Bill
January 27, 2018, 11:48:10 PM »
Had the same problem with an XBR a while back. I think I managed to slide a flat piece of metal, under seat between seat and tail piece, and engage with seat leaver. Bit heavy handed, but worked 😉
January 28, 2018, 08:21:17 AM »
Thanks-i'll go find my tools and releasing fluid from the boxes of as yet unsorted boxes in the garage and report back.
January 28, 2018, 08:54:10 AM »
Martin... if in doubt just get the grinder out😉😉😉😉
Ps ... I am joking. I would defo be trying Bill's suggestion first, best o luck 👍
Reply #5 on:
January 28, 2018, 06:38:27 PM »
No luck yet,found some WD40 and a long screwdriver but no joy.As the roads have dried out i took if for a 25 mile spin-it started on the electric fine.Reckon i might gain some access via the sidpanels.Checked the lock again after the ride but it's still not turning.Fiddling with the screwdriver and a torch refused to move the mechanism either-i've sprayed it again with the WD................
xbr500 xbr 650 nx 650 gsx1100
Reply #6 on:
January 31, 2018, 09:29:58 PM »
the actual lock spins in the tailpiece from age, get a coat hanger or similar put a hook on the end of it ,if you look over at the taillight between the light and tail piece you will see the a lock arm , hook on the coat hanger on and pull it toward you and it should open
Reply #7 on:
January 31, 2018, 09:38:18 PM »
Thanks Tommy.
Reply #8 on:
February 05, 2018, 07:23:39 PM »
Try pushing down on the seat and turning the key, works on mine
Reply #9 on:
February 06, 2018, 06:18:47 PM »
Thanks-been too busy last weekend picking up Moto 63's RS250 so will investigate further soon.....
Reply #10 on:
February 06, 2018, 09:20:31 PM »
Quote from: xbally on February 06, 2018, 06:18:47 PM
Reply #11 on:
February 06, 2018, 11:55:09 PM »
I'm sure you'll get over it 😉
Reply #12 on:
February 07, 2018, 08:28:46 AM »
Yes I'm sure I will Tim, got over much worse. Gotta say tho it was one of those bikes that was hard to hand over. Still now got a couple o quid to inject into the tracker project (which is moving on, albeit quite slowly)
Reply #13 on:
February 11, 2018, 04:32:27 PM »
Got a cheap exhaust for the RS off Fleabay but still no time to investigate the seat lock but all advice gratefully taken on board.
Reply #14 on:
February 11, 2018, 04:42:57 PM »
What's the exhaust Martin?.... a motad 2into1 or original Honda?
3
