Author Topic: XBR SEAT LOCK WON'T DISENGAGE  (Read 2006 times)
Re: XBR SEAT LOCK WON'T DISENGAGE
« Reply #15 on: February 11, 2018, 10:18:43 PM »
It's a home brewed 2 into one from the standard set up exiting on the left of the bike Michael!
« Reply #16 on: February 12, 2018, 08:00:42 AM »
Sounds quite nice, if it's be executed properly. Look forward to hopefully seeing some photos of the rebuild in the "projects" section at some point 👍👍🏍🏍
« Reply #17 on: February 27, 2018, 03:45:06 PM »
Just wondered how you got on with the XBR seat lock Martin, did you manage to get it sorted and get the seat off??
« Reply #18 on: February 27, 2018, 07:52:59 PM »
Sorry-weather too cold and we have electrical problems at the new bungalow so haven't had time to look further into this.On the plus side base is  in for new workshop but tools are still buried in the garage!
« Reply #19 on: February 28, 2018, 08:49:09 AM »
Slowly, slowly catchy monkey.... I think the saying goes Martin. Having just received the keys to our new house/project I can totally understand where you're coming from. Absolute shed loadda work to do with it. Hopefully this tIme next year it'll have been worth the grief 😢😢🤘🤘
« Reply #20 on: February 28, 2018, 06:42:42 PM »
Yes,thank you Micheal-good luck with your property venture. I start my temporary 3 day week with my old employers on Monday having completed my redundancy notice period with them today!
« Reply #21 on: February 28, 2018, 07:56:19 PM »
Cheers Martin, least I'm lucky enough that it's got a full double garage and I'm going to slightly extend it to hopefully pop a lathe and pillar drill in there. Best of luck with the semi retirement/3 day week... 👍👍
« Reply #22 on: March 31, 2018, 12:00:29 PM »
Is it going to be more than you had previously, Michael? Is that even possible?! :P
« Reply #23 on: March 31, 2018, 03:18:08 PM »
Afternoon Matt... yes it will in actual area be a touch bigger than before once finished but since my accident I've peared down my bike collection and my good lady wife is quite insistent that her car is going in the new garage as well as my bikes and bike bench etc. That's why I'm taking the opportunity to extend it a touch so I can defo get a lathe and pillar drill in there which is what I always intended to do with where we are now. Going to be a lot of work to do this year but hopefully this time next year I shud av a cracking workshop 😁😁🔧🔩🏍
« Reply #24 on: March 31, 2018, 03:54:18 PM »
Cars in the garage?! I gave up wardrobe space in exchange for having our single garage for my bike  8)
Oldtimer
« Reply #25 on: July 23, 2018, 11:00:47 PM »
Got a cheap exhaust for the RS off Fleabay but still no time to investigate the seat lock but all advice gratefully taken on board.
I assume you have the seat hump removed off the seat? If you get someone to turn the key to the unlock position and yourself waddle the seat itself about, you will find it will release itself.
Mike
Honda XBR500
« Reply #26 on: July 28, 2018, 08:52:56 AM »
D'you know what i have so much going on in my life that i completely forgot about this little problem as i haven't needed to get the seat off!
« Reply #27 on: November 11, 2018, 11:16:53 AM »
Just had to come back to this problem as i need to charge the battery.(Thank God for the old fashioned kick starter and de-compressor!) No matter what i do i can't seem to shift it. There's a massive gap between the seat and tail piece into which i can insert a screw driver etc but i can't seem to dislodge the lock mechanism whatever i do. I'm sure there's a knack to it which i obviously haven't got and no amount of wiggling,pushing or pulling on the seat seems to make any difference. I don't want to break anything so i am being as careful as i can!Thanks to all posters for advice to date!
« Reply #28 on: November 11, 2018, 12:16:40 PM »
Success!!!!!!!!!!!!I have tried a bit harder now .It helps if you can actually see! Put the bike in sunlight and noticed there is a catch on the lock mechanism which you can easily release with the blade of a screwdriver between the seat and rear bodywork. Only taken me nearly all of this year to work this out with help on here doh!
« Reply #29 on: November 11, 2018, 12:43:07 PM »
As I said, I think back in February Martin. Slowly, slowly catchy monkey 😁😁😁. Least you've got it sorted. By the way, how's the ktm doing? You enjoying it? .... cheers, Michael
