Author Topic: XBR SEAT LOCK WON'T DISENGAGE  (Read 2005 times)
« on: January 27, 2018, 06:23:09 PM »
As my bike hasn't turned a wheel since i put it in the garage at our new house on 23rd of December i decided to charge up the battery but i can't access it as the key doesn't turn fully in the lock so the seat can't be removed. They are never a good fit in my experience but is was working last time i used it which could have been several months ago now.Any ideas please on how to the seat off?
Re: XBR SEAT LOCK WON'T DISENGAGE
« Reply #1 on: January 27, 2018, 11:41:31 PM »
Aye xbally,
Soak the lock in PlusGas-A or a similar releasing oil, give it at least 24 hours to soak and the apply more and gently wiggle the key in the lock!
All the best, Bill
« Reply #2 on: January 27, 2018, 11:48:10 PM »
Had the same problem with an XBR a while back. I think I managed to slide a flat piece of metal, under seat between seat and tail piece, and engage with seat leaver. Bit heavy handed, but worked 😉
« Reply #3 on: January 28, 2018, 08:21:17 AM »
Thanks-i'll go find my tools and releasing fluid from the boxes of as yet unsorted boxes in the garage and report back.
« Reply #4 on: January 28, 2018, 08:54:10 AM »
Martin... if in doubt just get the grinder out😉😉😉😉
Ps ... I am joking. I would defo be trying Bill's suggestion first, best o luck 👍
« Reply #5 on: January 28, 2018, 06:38:27 PM »
No luck yet,found some WD40 and a long screwdriver but no joy.As the roads have dried out i took if for a 25 mile spin-it started on the electric fine.Reckon i might gain some access via the sidpanels.Checked the lock again after the ride but it's still not turning.Fiddling with the screwdriver and a torch refused to move the mechanism either-i've sprayed it again with the WD................
« Reply #6 on: January 31, 2018, 09:29:58 PM »
the actual lock spins in the tailpiece  from age, get a coat hanger or similar put a hook on the end of it ,if you look over at the taillight between the light and tail piece you will see the a lock arm , hook on the coat hanger on and pull it toward you and it should open  :o tommy
« Reply #7 on: January 31, 2018, 09:38:18 PM »
Thanks Tommy.
« Reply #8 on: February 05, 2018, 07:23:39 PM »
Try pushing down on the seat and turning the key, works on mine
« Reply #9 on: February 06, 2018, 06:18:47 PM »
Thanks-been too busy last weekend picking up Moto 63's RS250 so will investigate further soon.....
« Reply #10 on: February 06, 2018, 09:20:31 PM »
« Reply #11 on: February 06, 2018, 11:55:09 PM »
I'm sure you'll get over it 😉
« Reply #12 on: February 07, 2018, 08:28:46 AM »
Yes I'm sure I will Tim, got over much worse. Gotta say tho it was one of those bikes that was hard to hand over. Still now got a couple o quid to inject into the tracker project (which is moving on, albeit quite slowly)
« Reply #13 on: February 11, 2018, 04:32:27 PM »
Got a cheap exhaust for the RS off Fleabay but still no time to investigate the seat lock but all advice gratefully taken on board.
« Reply #14 on: February 11, 2018, 04:42:57 PM »
What's the exhaust Martin?.... a motad 2into1 or original Honda?
