Technical
Bike Problems/Questions
Cat `D`
Topic: Cat `D` (Read 459 times)
Sunny Dumfries
Cat `D`
January 20, 2018, 09:46:00 PM »
I need a frame for a suzuki gn250, found one that is cat D, would this be a problem or a straightforward build, it has a v5,
Re: Cat `D`
January 21, 2018, 10:17:13 AM »
Should be OK - Cat D doesn't need to be inspected, whereas a Cat C does. The categories have recently changed although I don't think significantly.
Presumably you're building it as the bike with the new frame, in which case of course you just need to tell DVLA of the changed engine number. At least that's all I had to do with my Arrow.
The only issue would be when you come to sell it on.
Sunny Dumfries
Re: Cat `D`
January 21, 2018, 10:57:11 AM »
thanks Ian, if i can`t find another cheap gn i will probably get a frame then, someone has sawn the front of the spare one i bought...
Technical
Cat `D`
