Author Topic: gn250 cam chain adjustment  (Read 469 times)
« on: August 20, 2017, 09:34:12 PM »
Ok, after many years of gn ownership i still haven`t ever checked any of the bikes cam chains,  how do you adjust them ?   i have also never seen a service manual anywhere, do they exist ?
Re: gn250 cam chain adjustment
« Reply #1 on: August 20, 2017, 10:03:33 PM »
Aye spooky,
eBay Lot Number: 361980240218
I know it's in the 'Land of the long white cloud', but if needs must.  ;)  Drop the man a message to find out more. I have no connections with the seller.
« Reply #2 on: August 23, 2017, 12:11:57 AM »
i think the term 'automatic camchain tensioner' is pretty self explanatory.
« Reply #3 on: August 23, 2017, 08:39:28 AM »
where does it say `automatic cam chain tensioner ` ?
« Reply #4 on: August 23, 2017, 10:02:16 AM »
Nearly all modern OHC engines have auto cam chain tensioners Spook, unless they're belt driven like my 500 Rotax!
That's not to say that they always work correctly though, and IIRC certain Suzuki ones are prone to sticking, and benefit from some faffing around with the preload adjustment screw to get them working again. All are prone to wear as well, and will only last for a certain amount of time before either the cam chain has stretched too much for the tensioner to work, or the slipper part of the tensioner that is in contact with the chain has worn out, or the spring has broken etc, etc.
It's easy enough to pop them out for inspection though, and all you need is to undo the two bolts holding it into the engine, and probably a new gasket when you re-install it. On the DR350, it's at the back of the barrel at the bottom right as you sit astride the bike. I expect it's in the same place on the GN.
HTH.
« Reply #5 on: August 26, 2017, 04:00:22 PM »
method to check operation of automatic camchain tensioner;
1, start engine.
2, is it rattling?
3, if answer to point 2 is 'no', then auto tensioner is operating correctly.
