Author Topic: XBR wiring info  (Read 658 times)
XBR wiring info
« on: April 05, 2007, 08:19:47 PM »
Anyone got a manual handy (mine's on loan to a mate).
I need the info on how to test the alternator output.
Re: XBR wiring info
« Reply #1 on: April 05, 2007, 09:21:14 PM »
The manual says:  remove main fuse and connect ammeter across main fuse terminals and voltmeter across battery terminals.
Disconnect the black wire from the reg/rec coupler.  Start engine and check charging output at the speeds as follows:
                           A                             V
1,200 rpm       (+) 8A                      Above 12V
3,000 rpm        (+) 12.5 A                14-15 V
8,000 rpm       (+) 13.5 A                  14-15 V
Re: XBR wiring info
« Reply #2 on: April 05, 2007, 10:52:33 PM »
You can check the AC output direct at the alternator too.
At the block connector should reab about 75v AC.
Dont forget to check the resitance between the coils and continuity to earth for each coil.
