Author Topic: Just regular maintainance  (Read 839 times)
« on: January 08, 2017, 04:31:25 PM »
Well my supercharger project is well on the way to completion, so I thought I would take a break and do some ordanary servicing.  I thought I would replace the old and loose cush drive, while the rear wheel was out I noticed that the bearing was a bit rough so I thought I would knock it out and change them, what a pain-- literally, I think I hit my knuckles more that I hit the bearing :( the upshot is the bearing hasnt moved but neither can my finger this morning. Tomorrow I shall try plan B, fill the brake drum with boiling water and see if that loosens it. Wish me luck :)
Re: Just regular maintainance
« Reply #1 on: January 08, 2017, 08:31:26 PM »
Sounds like a plan, good luck  ;)
« Reply #2 on: January 08, 2017, 11:08:54 PM »
hi joolz the last wheel bearing i did on a xbr fell out the minute i touched it worn hub (d,oh) so at least you dont have that problem eh ,plenty of heat should shift it and stick a big rawl plug in it to get  some purchase on the bearing tommy
