Author Topic: Start of the winter rebuild  (Read 7319 times)
Re: Start of the winter rebuild
« Reply #15 on: November 26, 2016, 08:13:16 PM »
Not much news lately, the crank will be with me Monday or Tuesday after having the new conrod fitted by Eastwood racing, a new genuine Honda left hand crank bearing is being sent by Dave silvers.
In the mean time I have painted the cases and rocker cover.
The cylinder head has been cleaned and the combustion chamber has been reshaped into a cross between the original shape hemi and a pent roof combustion chamber by cutting the chamber at a flater angle to the valves then blending it in (you can just about make it out looking at the picture), a bonus is that the spark plug tip is less shrouded, this has also increased in volume from 60cc to 75cc which will give me a compression ratio of 7.5:1 with the spacer plate and the piston I have.
Already thinking about next year, I am going to put an ignitech programable ignition on the bike it has a single wire activated 2nd ignition map, so I can have a cruise map with lots of advance to support the low compression motor and a retarded map when on boost activated automaticity by a pressure switch in the intake plenum, I also want to fit new seats and 2mm oversize exhaust valves, but cant afford either of these this year
« Last Edit: November 27, 2016, 03:38:18 PM by JOOLZ »
« Reply #16 on: December 01, 2016, 01:44:05 PM »
Cases are cleaned and repainted, just waiting for the crank bearing now
« Reply #17 on: December 01, 2016, 02:37:21 PM »
Looking good joolz.....even I'm starting to get excited and it's not my bike ;) ;)...cheers, Michael
« Reply #18 on: December 01, 2016, 07:45:17 PM »
Aren't we all. Some piece of work  :)
« Reply #19 on: December 02, 2016, 11:30:27 AM »
Looks like some awesome engineering going on here, fantastic! :)
« Reply #20 on: December 22, 2016, 09:58:05 AM »
Its all starting to come together now
« Reply #21 on: December 22, 2016, 02:05:32 PM »
Lovely, shiny, engineered baubles in the front room at Christmas! 😋
« Reply #22 on: December 27, 2016, 03:57:44 PM »
Another bit finished, alternator spacer allows me to use the XBR high output alternator with the XL crank, rotor and cover
« Reply #23 on: December 28, 2016, 07:21:12 PM »
Its slowly starting to look like a motorcycle again
« Last Edit: December 28, 2016, 07:23:42 PM by JOOLZ »
« Reply #24 on: December 29, 2016, 11:46:01 AM »
Yep proper engineering, unlike my bodging  :-\ Looks fantastic  :)
« Reply #25 on: December 29, 2016, 07:03:23 PM »
Thanks, Its reasonably engineered but its not perfect :) I found a way to fit the XBR chain cover with the XL alternator cover, narrowed the cover by 10 mm lines up quite nicely and looks ok
« Reply #26 on: December 29, 2016, 08:55:46 PM »
Looks like it was made by Honda - you must be well chuffed!
« Reply #27 on: January 14, 2017, 07:36:49 PM »
I have done a little bit more work I have started to make the intake plenum with a pop off valve
« Last Edit: January 15, 2017, 01:50:16 PM by JOOLZ »
« Reply #28 on: January 14, 2017, 07:39:31 PM »
I have started on the plumbing, and its a very tight fit, this is the reason why I had to use an XR600 R inlet rubber. I also had to trim a fin so the pipe could route correctly
« Reply #29 on: January 23, 2017, 07:04:17 PM »
Dry fitting the plenum not much room left in there
