Author Topic: XBR Cylinder head cover oil leak  (Read 414 times)
« on: September 04, 2016, 08:50:55 AM »
At first I thought the oil was coming out at a sub rocker shaft seal, but it turns out it had travelled back and down from a pool around the uppermost 8mm bolt on the cylinder head cover. I tightened it a smidge but no result. Any help greatly appreciated.
Re: XBR Cylinder head cover oil leak
« Reply #1 on: September 04, 2016, 09:10:40 PM »
If you don't have the inclination to strip and clean and put new gaskets about the place; or are feart to overtighten the bolt, try a smear/drop of this stuff!  ;)
Captain_Tolleys_Crack_Cure_Sealant
I can hear the cackling now at the name  ::) , but can vouch for its worth and in spite of earlier posts about scrutineering  ::) this definitely deals with wee "weeps" and mists from gaskets etc, permanently, until the next strip down.
BUY IT DIRECTLY FROM THE MAN HIMSELF, FAR CHEAPER THAN FROST's!  :-X  And with a sale price for the large bottle at present.   ;)
« Reply #2 on: September 05, 2016, 10:34:21 AM »
Thanks for the tip. I'll leave the bolt in-situ and clean the oil off before applying on top and around it's washer. Great name, as you say!😱
