Author Topic: Weird engine noise (SRX400)  (Read 446 times)
guest2039
« on: June 06, 2016, 04:42:11 PM »
Hello, I've recently bought a '96 SRX. This is my first motorcycle and I absolutely love it. There is one problem however  — there's a funny noise coming from the engine. It sounds like rubber being chewed by something. It comes and goes, sometimes becomes louder, being audible over the lumpy Supertrapp exhaust.
I don't know much about motorcycles, should I be concerned? It starts and runs perfectly, but this noise is somewhat bothering.
This motorcycle isn't popular in my country, four-cylinder sportsbikes are preferred over here, so it's practically impossible to find help online.
Hopefully my description of the issue proves helpful enough :)
Re: Weird engine noise (SRX400)
« Reply #1 on: June 06, 2016, 09:32:04 PM »
obvious stuff first, have you checked the oil, and adjusted the valve clearances?
guest2039
« Reply #2 on: June 07, 2016, 06:05:15 AM »
I have checked the oil, it is a couple of inches over the "max" mark. Could this be the cause? If so, how do I drain that extra oil?
As for the valve clearance —I don't really know what that means and whether it can be done by an unskilled person like myself. I will google the process and do it.
Thanks for your input!
« Reply #3 on: June 07, 2016, 09:36:28 AM »
I think that could easily be the cause but it's tricky to know without hearing it.
I tend to change the oil as a matter of course on a new (to me) bike unless I know it's just been done.
I wouldn't have thought valve clearances would give the sort of noise I imagine you're describing.
