Author Topic: Brake Pads  (Read 491 times)
Oldtimer
Brake Pads
« on: March 18, 2016, 12:46:01 PM »
With such a plethora of pads on the market, which one do you go for? I ride my XBR occasionally but when I do I do tend to brake heavily on the front brake. Which one would you recommend? Brembo pads look OK but which one?
Look forwards to your recommendations.
Mike
Honda XBR500
Re: Brake Pads
« Reply #1 on: March 18, 2016, 02:07:52 PM »
I've used Brembo pads before and they were fine, these days I tend to use EBC but for no particular reason. Generally get a known brand rather than some you see on Ebay etc. Sintered pads were thought to give better braking but wear the disc a bit faster. Big thing I've found with XBR's is to check that both brake pistons are coming on evenly, XBR's tend to suffer with sticky pistons and I often found that one is coming on more than the other which makes a big difference to the brake performance. Working properly I've never found the XBR front brake wanting for normal road riding.
Oh, if you don't already have one get a braided front brake hose, that helps too.
Oldtimer
Re: Brake Pads
« Reply #2 on: March 18, 2016, 03:08:10 PM »
Every thing is fine at the moment, it is just that since purchasing the bike over 4 years ago I have never had cause to change them. They are working fine at the moment it is just a precautionary measure. The same thing with the spark plug, never had it out!
Mike
Honda XBR500
Re: Brake Pads
« Reply #3 on: March 18, 2016, 06:15:34 PM »
It's worth just loosening it a few tyrns then nip it up again from time to time as they can get very tight.
Dick Scratcher
Re: Brake Pads
« Reply #4 on: March 18, 2016, 07:17:36 PM »
I've fitted some 'GoldFren' sintered pads to the front of my CB250RS and quite frankly they don't seem as good as the EBC ones.
Re: Brake Pads
« Reply #5 on: March 18, 2016, 08:27:20 PM »
Again, for no particular reason, I tend to use EBC pads.
theoneandonlymin
Re: Brake Pads
« Reply #6 on: March 19, 2016, 08:09:44 AM »
Ferodo Platinum are the biz. Wet braking is great.
Min
Oldtimer
Re: Brake Pads
« Reply #7 on: March 19, 2016, 01:05:34 PM »
Min
Wet Braking!!!!!!!! fine weather rider--------
Mike
Honda XBR500
