Author Topic: SLR 650  (Read 453 times)
guest1963
SLR 650
« on: July 19, 2015, 06:24:24 PM »
CAN ANYONE TELL ME IF THE BOTTOM ENGINE BOLT ON THE SLR 650 IS THREADED INTO THE ENGINE MOUNT I DON,T THINK IT IS BUT MINE IS STUCK SOLID IT MOVES WITH THE ENGINE WHEN U ROCK IT ANY SUGESTIONS
Re: SLR 650
« Reply #1 on: July 19, 2015, 07:35:56 PM »
hi I,d say its seized cant see it threaded in  there not threaded  on xbr /nx ,s plenty of wd 40 or similar and a bit of heat might move it with luck   tommy
« Last Edit: July 19, 2015, 07:39:52 PM by tommy »
guest1963
Re: SLR 650
« Reply #2 on: July 19, 2015, 08:09:11 PM »
JUST AS I THOUGHT  THANKS
Re: SLR 650
« Reply #3 on: July 19, 2015, 08:17:48 PM »
Will take a look at my Vigor tomorrow, but im almost sure the end of the engine mounting bolts are just threaded on their ends to take a nut. I have encountered engine bolts where the bolt shaft is corroded into the alloy of the crankcase. A total b@@@@@@ :(
Try Plusgas and applying localised heat of the alloy around the bolt. Pouring boiling water from a kettle might free it, or careful use of a blow torch. At worst, you may have to drill it out.
Re: SLR 650
« Reply #4 on: July 23, 2015, 08:51:13 PM »
I concur Timbo, I had to drift out the lower engine bolt on my XBR even though it was only 11 months old at the time. A good coating of grease is essential.
