Author Topic: THE FUEL DIAMOND  (Read 692 times)
guest1964
THE FUEL DIAMOND
« on: March 31, 2015, 12:51:34 PM »
Hi all
Has any one used this fuel diamond?
If so any feed back?
FUEL EMULSIFICATION is a real pain in the a*s..kills kwakers
Just how do they get away with selling C***py fuel.. >:(
THE FUEL DIAMOND REDUCES THE RISK OF THE PETROL IN YOUR FUEL TANK GOING STALE OVER WINTER LAY OFFS INFACT IF YOU HAVE A CAR OR MOTOR CYCLE THAT YOU DO NOT OFTEN REFUEL DUE TO LITTLE USE THE FUEL DIAMOND WOULD BE IDEAL FOR YOU TO USE.THE FUEL DIAMOND STOPS THE WHAT CAN BE A RAPID DROP IN OCTANE
IT STOPS THE CHANGE IN FUEL COLOUR
IT STOPS EMULSIFICATION
guest1964
Re: THE FUEL DIAMOND
« Reply #1 on: March 31, 2015, 01:21:55 PM »
Quote from the dreaded Wicki P "Vinegar is a liquid consisting mainly of acetic acid (CH3COOH) and water. The acetic acid is produced by the fermentation of ethanol by acetic acid bacteria."
So, as you can see the added ingredient of 'petrol' may turn to vinegar in your tank like an opened unfinished bottle of Beaujolly! I know, that's anathama to many on this site!
So the fuel diamond may be killing the bacteria?
« Reply #2 on: March 31, 2015, 09:05:52 PM »
Sorry Chris, I'm not familiar with this product, but a mate who works at chainsaws and similar for a living swears by a Briggs and Stratton fuel stabiliser, that he also uses in his bikes.
Personally, all I ever do if I'm laying up a bike for a bit, is drain the tank, then suck the remainder out by using a tube on a vacuum pump, then leave petrol cap off for a bit, to allow anything left to evaporate. Also drain carbs. Sounds a lot of hassle, but only really takes a few minutes.
« Reply #3 on: March 31, 2015, 10:19:21 PM »
Me too - Also drain the carb bowl!
« Reply #4 on: April 01, 2015, 11:38:25 AM »
I've used a fuel stabilizer for the last couple of winters in my 'best' bike and after both winters the bike started first push of the button in the sprng. Of course, it may have done so anyway, and I know a lot of people think fuel additives are snake oil.
