Hi again. To drain oil, there are two drain bolts, one on the left hand side of the the front down tube, and the other on the left hand side of engine, near the gear change. I have always used 10/40 semi synthetic oil in any bikes of this ilk. Currently im using Motul. Change oil every thou to fifteen hundred miles.
To remove oil filter, its the small cover held on by three bolts on right hand side of engine. Be aware of spring behind filter, and small protrusion on cover that lines up with same on engine when replacing filter.
The bit that always gets me is how to properly check the oil level on any of these bikes, eg xbr, dommie, SLR, vigor. You must take the bike for a short run first, maybe a couple of miles say, then let it sit at tickover for two to three minutes. Switch off, then check oil immediately using dipstick in top of frame. Using any other method, I have found, gives vast variations in oil level
As for uploading pics, I have to get my PA/wife/brains of the outfit, to do that. She's tried to show me, but I'm afraid that tech talk has transformed into white noise when it reaches my few remaining braincells
