Not so good over here I'm afraid :-( and all pretty much self inflicted.
After getting a nasty shock when Dolly decided she didn't want to lean as far as I wanted her too and slipped across two lanes I thought it about time to replace the rear and check the pressure in the front. I knew the rear was bald, but was a little shocked to find only 16PSI in the front :-0
Saturday AM forced to buy a trolly jack to pick the back end up as I couldn't get two neighbours to lift Dolly onto the mini tressle . (grumble grumble) Fought for 1/2 hour to break the tyre off the rim and proceeded to remove old and re-fit new. Bugger! Pinched the inner tube! (grumble grumble) 1/2" split=useless so it's a mile walk (wifey off with the car) to buy a new one. Pump some air into the new tube to give it some shape and proceed to fit it, but I've got too much air in it so I remove the valve. Struggle to get everything on and go to pump up only to find it wont hold air! (grumble grumble) I assume I've pinched it again so as soon as I've stopped swearing at the bloody thing, I remove the inner tube to inspect it only to find the reason it wont hold air is cos I haven't replaced the valve! (grumble grumble) Loads and loads of swearing, 10 deep breaths, and put everything back together again. Job done, out with the pump and.......... I've pinched the inner tube again!!!!! The air is purple and my neighbours are coming out into the street to see what all the noise is about, only to see me shouting at a wheel and threatening it with a tyre lever while it lies on the floor in complete defiance. Wife is home by now, so I'm off to another bike shop to get another innertube (can't face going to thew first shop and admitting I popped it) Finally at 3pm, I finished the job that I started at 10am.
But my biking misery wasn't over. Due to the stress of fitting the tyre, I retreated to the sanctuary of the pub and watched the rugby. This meant I was left with fitting the new chain on Sunday. Couldn't be as bad as Saturday I thought, but I was wrong. I ordered a 'split link' chain, but after removing the old one (and buggering the spring clip) I discover its a 'soft link' version instead. I don't have the tool and I have to get things back together for Monday, so I struggle on! Basically, I've two 'G' clamps holding a spanner across the back of the link, then some 1mm spacers jammed along the 'O' rings so I don't clamp things too tight. Next I use the mole grips to hold the face plate in place. It springs off and I spend 1/2 an hour on all fours searching for it, swearing lots (mostly about bloody bikes, why's my life so shitty etc etc) Once found, I clamp it in place and attack the soft link with a ball point hammer untill I've neatly riveted the link in place.
That was a weekend I can't forget too soon I can tell you! The only light was the Good (for England) rugby result :-) Lifes not so bad.
