dear Propellor
this are manual pics:.......
Thanks for the photo mehranx. My interpretation of the information is that we are allowed a service limit clearance (diametral clearance) of 0.150mm on both the left hand and right hand journal. By definition this is not the original clearance, when the bike was new. I'm not sure what clearance to aim for. That was one of my questions. Anybody else know?
Apologies if you already know the following, but in case you don't, a thousandth of a millimetre is a micron. A " thou" is a thousandth of an inch in engineering terminology, over here.
We know the Japanese get these camshafts to run very satisfactorily in aluminium, indeed they have made an art of it, so for yours to have failed something must be different. Stating the obvious!
Is it surface finish, clearance, alignment or because the grade of aluminium is different? Or a combination of all those factors.
My point being that if one of the first three is the reason, then it is possible that even with a bronze bush you might still experience a mechanical failure.
Cheers.
Edit: is the oil pump delivering a good supply of oil to the top end?
