Author Topic: Replacement seat cover  (Read 648 times)
Oldtimer
« on: January 13, 2015, 12:36:50 AM »
I am after a seat cover for an XBR. I plan to do it myself to save on cost.
Any idea's where I can get one from would be much appreciated.
Mike
Honda XBR500
Re: Replacement seat cover
« Reply #1 on: January 13, 2015, 08:32:51 AM »
 Wemoto sell them about £20-£30 ish.
http://www.wemoto.com/bikes/honda/xbr_500_h/87/picture/seat_cover_-_economy_from_far_east/
 £20 for a Far Eastern made one or £30 for a UK made to order one.
Dick Scratcher
« Reply #2 on: January 13, 2015, 07:58:56 PM »
I don't know what the seat pan is made of on the XBR but if it's a nylon/plastic affair with the cover stapled on as on my RS You will probably need a powerful stapler, the 'normal' DIY jobs aren't up to it, I know, I've tried.
booxbr
« Reply #3 on: January 13, 2015, 10:37:02 PM »
Had mine re covered by a guy at Huddersfield called Tony Archer  did put some pics on here charged me £60 .......
pisc are in topic  Recommend Services... seat recovered
« Last Edit: January 13, 2015, 10:42:44 PM by booxbr »
« Reply #4 on: January 14, 2015, 10:09:17 AM »
They are plastic seat bases, you will need a powerful staple gun to go through it, I recovered my seat last summer, its a bit of a job keeping it wrinkle free but go steady and you will be ok
500 T C
« Reply #5 on: January 14, 2015, 06:09:12 PM »
One tip, soak the cover in hot water, to make it more supple,and easier to fit. ;)
Oldtimer
« Reply #6 on: January 15, 2015, 01:42:02 AM »
Thinking of using one of these. Friend of mine has done his and made a good job of it. They are about £12.
Mike
Honda XBR500
Silverfox
« Reply #7 on: January 15, 2015, 06:10:23 PM »
I bought off ebay seat cover material that stretches 4 ways, I  recovered my divvy seat and its pretty good, it is a smooth material rather than the textured original but it was relatively easy to do and no creases! I would definitely use this fabric again when I need to redo a seat. I heated the base as I went along with a hairdryer which made stapling a lot easier with a standard staple gun.
Gareth
Silverfox
« Reply #8 on: January 15, 2015, 06:13:47 PM »
ebay number - 290342865007  pretty sure this is the same material I used.
Oldtimer
« Reply #9 on: January 18, 2015, 06:17:15 PM »
I'll give this some thought as it will be cheaper than WeMoto  If I mess-up cheap enough to get another.
Mike
Honda XBR500
« Reply #10 on: January 26, 2015, 09:30:42 PM »
I like the look of that spike strip product. I'm sure you could rivet it onto a plastic seat base. Good luck, and let us know how you get on. :)
