Author Topic: Xbr/xl600 cdi unit  (Read 666 times)
Xbr/xl600 cdi unit
« on: July 30, 2014, 10:15:38 AM »
Morning all,
Am I correct in thinking that if I swap the cdi unit from the XBR to one from an xl600r that it will improve the performance of the XBR ?  Thanks in advance    Michael
Re: Xbr/xl600 cdi unit
« Reply #1 on: July 30, 2014, 04:54:56 PM »
I believe you need the CDI from an XL600R -  it has more advance than the XBR unit and pepps it up quite a bit I'm told ( though I haven't tried it). I think it just plugs straight in - PM Joolz he knows.
« Reply #2 on: July 30, 2014, 05:26:34 PM »
Many thanks for the reply Steve , I,ll try pm,ing joolz see if he can shed some light on the subject. In the meantime if anyone else out there in thumper land knows the answer pls get in touch.  Regards Michael
« Reply #3 on: July 30, 2014, 07:27:27 PM »
I run an XL600R cdi, plugs straight in and will give you a bit more advance. However I have been told that you cant use an electric start with it, I cant verify that as I dont have an electric starter fitted
« Reply #4 on: July 31, 2014, 08:36:37 AM »
Morning joolz,
Thanks for the post, the lack of lecci start would,nt be a problem as I also don,t run one. Think I,ll cost a unit up n give it a try.  Regards Michael
« Reply #5 on: July 31, 2014, 10:13:03 AM »
I have recently been looking at the crank trigger, I have heard but cannot confirm that some models (I think the XR600) has a wider crank trigger that could give you more advance when fitted to the XBR. There is also a fully programmable cdi available for the XBR, Here is the link   http://www.ignitech.cz/en/vyrobky
and here is a link on the XL cdi box   http://www.scribd.com/doc/56944238/Cdi-Xl600-en
« Last Edit: July 31, 2014, 02:18:16 PM by JOOLZ »
« Reply #6 on: July 31, 2014, 03:07:21 PM »
Hi joolz,
Thanks again for post and link, I,ll check it out. I,ve been onto David silver spares and the xl600r cdi unit no longer available as a new part, may have to give fleabay a go. Thanks again. Regards Michael
