Author Topic: Suggestions on glue to use to fix this  (Read 930 times)
guest24
« on: July 09, 2014, 09:32:07 PM »
I have used silicon sealant before and that seems to be holding well on the other inlet rubber.
Just wonder if there is a better glue anyone knows about?
Attachment Expired
guest1406
Re: Suggestions on glue to use to fix this
« Reply #1 on: July 10, 2014, 04:28:42 PM »
I use gorilla glue a fair bit and would recommend it
Mackenzie
500 T C
« Reply #2 on: July 10, 2014, 05:18:14 PM »
Believe it or not Evostik,preparation is the answer thin the glue out with paint thinners and paint it on both items and let it dry completey,then fit both items together, sorted. All the rubber components fitted to Lynx helicopters are fitted like this,,,, yes I was that man.
guest24
« Reply #3 on: July 10, 2014, 05:24:04 PM »
Thanks for the responses chaps.
Never heard of gorilla glue - I will investigate that one some more.
500TC, by paint thinners do you mean white spirit or cellulose thinners?
500 T C
« Reply #4 on: July 10, 2014, 05:55:00 PM »
               Yes, sorry, cellulose thinners ::)
« Reply #5 on: July 11, 2014, 07:21:19 AM »
Gorilla glue is a polyurethane based glue which moisture cures, good stuff but expands quite a bit as it,s curing so ideally needs the pieces clamping together
« Reply #6 on: July 11, 2014, 07:53:08 AM »
+1 for the old fashioned Evostic. It also cure hardens with heat. Trick is to keep parts clean and then after adhesive is applied, not to assemble too quickly.
I use it all the time to make bath sides! :o
guest24
« Reply #7 on: July 11, 2014, 06:20:55 PM »
Evo-Stick and thinners shopping here I come!
« Reply #8 on: July 12, 2014, 09:05:32 AM »
You know you have to be over 18 to buy this stuff now??.... and best to remove any signs of glue from around your face before going in the shop!!
pip pip
guest24
« Reply #9 on: July 12, 2014, 06:15:56 PM »
Over 18? No problem, I ordered mine from the internet so they couldn't see my face  ;)
Oldtimer
« Reply #10 on: August 08, 2014, 02:18:01 PM »
There is a high temperature silicone adhesive available now. They use it in exhaust pipes in place of Gun-Gum paste of old..
Mike
Honda XBR500
