Maybe the bottoming out in spite of extra spacers can be explained by the fact that spacers set preload and suspension sag but don't (can't) affect spring rate? A "soft" spring is soft no matter how many spacers are applied, no? The position the forks end up under heavy braking surely will be determined by the reaction into the forks under braking. For any given reaction (edit: and any given spring rate) won't this compress the springs to the same point to equal this force every time? Regardless of the number of spacers (amount of preload). Unless the force is less than the preload force, in which case no movement will occur at all.
Pretty much but if the springs are ie 35lb/in then you need another 70lbs of force to overcome the effect of the spacers.
Edited to correct units of force
Hi rhinoman (and steveC).
The above proposal and a comment by steveC have had me scratching my head, as to what actually happens when you add spacers.
This is how I see things. When you add your own weight to that of the sprung portion of the bike the springs will settle to a certain position to counter that force with a force of their own exactly equal to it. That force will equate to a certain length on the spring, according to the spring rate. With the same spring the same position (spring height) will occur each time, except for differences caused by stiction, but hopefully you see my point?
By adding (or subtracting) spacers we are changing the preload. But, as long as there is still some suspension travel ABOVE our static ride height, then we won't have changed anything about the height the spring settles to and therefore way the spring acts under braking. We will have changed the bikes "attitude" (so, indirectly, we have changed the way the bike behaves). Also, we will have altered how much travel is available, as a ratio, above and below static ride height (suspension sag). If we spacer all available travel above static ride height out, then that changes things as the bike acts as a rigid until a certain force is exceeded.
Is that right? I must admit, I'm not entirely sure I'm right! Certainly a confusing, but juicy, topic.
Hopefully I'm making some sort of sense, at least.
Cheers.
