Author Topic: xt600e starting problem  (Read 2030 times)
Re: xt600e starting problem
« Reply #15 on: July 04, 2014, 08:32:44 AM »
hi guys,
my compression tester arrived from ebay today, and maybe the single spark was a red herring!  compression reads 35 psi, 1200 psi less than it should.
looks like the heads coming off.
Since there is little or no compression I would expect it to spin very quickly on the starter, is this the case ?
« Reply #16 on: July 04, 2014, 09:33:21 AM »
And please tell me
us that you disconnected the automatic decompressor first !
guest1518
« Reply #17 on: July 04, 2014, 02:45:32 PM »
120psi, not 1200.
no, I didn't disconnect the automatic decompressor first.  I didn't know it had one, and I can't see it, and I can't find a reference to it in the workshop manual. I thought that it was only available on a kick start model.
If it does have one I need someone to tell me how to disconnect it.
Thanks for taking an interest in my build, it's much appreciated.
« Reply #18 on: July 04, 2014, 08:10:23 PM »
The 660 engines appear have an automatic decompressor built into the camshaft sprocket. The 600 Grizzly(Quad) seems to have a similar device but I cant see any reference to anything like it on the XT600E engines.
« Reply #19 on: July 05, 2014, 09:29:58 PM »
In which case I may be mistaken - My XT600 (kick and electric) has one and I assumed, perhaps wrongly, that the 660 engine fitted to my Skorpion would also have one.
« Reply #20 on: July 06, 2014, 10:47:49 AM »
I think the 5v motor does have an auto decompressor, but in this case we are referring to the xt600e.
I do not know, but I would think that the 600 motor would also require one. Tho I also know that when removed, the electric leg will still get it over compression.
Tho if it only makes 35psi on compression,  it wouldn't matter if it had one or not!
A
« Reply #21 on: July 07, 2014, 06:36:16 AM »
Are we discussing the kick-start decompressor here , in which case it wont effect the action of the electric start.
guest1518
« Reply #22 on: May 01, 2015, 12:29:40 PM »
Hi guys,  thanks to all who have tried to help me.  I've finally got my bike running, I fitted some new rings, which it didn't need, did the valves and seats, which it did need.  Still wouldn't start, so I bit the bullet and bought a new TCI
guest1518
« Reply #23 on: May 01, 2015, 12:34:45 PM »
I  had it running before the delivery guy was at the end of the road.
