Author Topic: XBR removal of air filter  (Read 539 times)
guest1703
« on: December 19, 2013, 03:00:29 PM »
Hi all
Do I need to do any adjustments to the needles or something like like, if I decide to remove my air filter box and replace with direct intakes?
Best
guest1744
Re: XBR removal of air filter
« Reply #1 on: December 20, 2013, 03:29:42 PM »
the air box is nearly as vital as the exhaust for power delivery - taking it off will sound fast with all the intake noise- and almost certainly wreck the power curve
you may get some more top end- and it will feel fast as you roll through the massive hole created in the middle
Don't do it!
« Reply #2 on: December 20, 2013, 09:11:49 PM »
I only know of one person that tried this and it didn't run at all well, an aftermarket carb is the only real way to go without an airbox.
« Reply #3 on: December 21, 2013, 12:08:12 PM »
Hi all
Funny thing this fuel air mixture malarkey , I ran my xbr cafe racer in "dry build " form all last year with the  STANDARD carb and a K and N pod filter and a stainless 2 into1 zorst system and ran without a beat missed. It would pull 90/100 with the only downside at the time being the slipping clutch which did make for some " entertaining" overtakes. The bike has since been completely stripped down, the engine included and been rebuilt to a higher state of tune, complete with brand new mikuni carb and the same K and N filter as before I have only had chance to do a couple of shortish runs as it now, but again so far it appears to run/ pull brilliantly.  Much better than a standard xbr.   Regards moto63
« Reply #4 on: December 21, 2013, 12:17:28 PM »
Ps. At the time I was running a "predator" 2 into1 zorst, it now has a different, much better 2into1 on. Cheers moto63
