Author Topic: fazer 600 fuel delivery problem?  (Read 381 times)
guest1757
« on: December 18, 2013, 10:02:07 PM »
Hi All, Any similar experience or advice would be apreciated
I have recently bought a second hand fazer. Generally rides great but a possible fuel supply fault. Whenever accelerator is applied it flies and wants to go. The problem appears when aproaching junctions, roundabouts the engine warning light appears orange. As second after accelerating through it goes out. Once hot the engine will idle sluggishly. If i switch off ignition the pump will recharge then idle as expected. I have stripped the tank and fuel pump to check for blockage at filter pick up. all clear and all wiring appears sound and free of any furring up.
Is there an electronic box that governs timing or is the pump defective? Anything else to check?
