Author Topic: Honda XBR alternative tanks  (Read 2274 times)
Re: Honda XBR alternative tanks
« Reply #15 on: December 16, 2013, 05:16:54 PM »
latest tank progress. I have fitted 2 cut down front tank mounting rubber and the xbr rear mounting rubber to the tank, and it bolts down fine.
I have now almost finished stripping the paint from the tank
« Reply #16 on: December 16, 2013, 05:19:37 PM »
Progress so far.
« Last Edit: December 16, 2013, 05:25:20 PM by JOOLZ »
« Reply #17 on: December 16, 2013, 07:02:04 PM »
Progress so far. Notice the spotless workshop, Suzanne keeps calling it the dining room for some reason
guest1444
« Reply #18 on: December 16, 2013, 07:26:35 PM »
Great looking job.
Now, a diffcult question.
Can you give me a width measurement for the tank - front and rear
        - top and bottom
Hard to measure I know, but to give you an idea of what I
guest1444
« Reply #19 on: December 16, 2013, 07:31:08 PM »
Sorry, hit return before finishing.
Great looking job, and well done.
Now, a diffcult question!
        - top and bottom
Hard to measure I know, but please give it a shot.
matthurl
Oldtimer
« Reply #20 on: December 17, 2013, 05:41:59 PM »
Hi old timer, yes there is enough clearance to drop the standard bars below the yoke with the original tank still fitted, you will just have to have them at a shallower angle other wise the switch gear will foul the tank. Also bear in mind that the clutch cable becomes slightly to long so best to custom make one up, venhill offer a good service.  I,ve built my xbr cafe racer doing exactly that and ran it for a year with no problems wot so ever.  Regards moto63
Cheers thanks for that. I didn't realise the clutch cable wold be to long though.
Mike
Honda XBR500
« Reply #21 on: December 18, 2013, 08:13:39 AM »
Hi old timer,
You kud always av a go at re routing the cable, I try,d a couple of different routes but in he end figured that a replacement would be a better job so put hand in pocket (rare thing for a Yorkshire man hee hee) and bought a venhill " build you're own" seems decent quality.   Good luck.   Regards moto63
« Reply #22 on: December 19, 2013, 11:24:15 AM »
        - top and bottom
matthurl
Ok I have some measurements for you 11cm at the front mounts 16cm front base of tank below the mounts.
18 cm measured 2cm forward of the fuel tap (to clear the frame rails) and rear, between the side panel mounting points 20cm.
I hope that helps
guest1759
« Reply #23 on: December 19, 2013, 05:41:16 PM »
A few years ago there were some nice steel tanks made in eastern Europe-Czech republic for instance, Gold Star as original, but just in bare metal. maybe even the Indian Bullet cafe race version alloy tank was made in E Europe? Just wondering if one was to take an XBR tank base and build a nicer looking remainder? Is this a metalworking possibility or too fiddly? (plus costly!)
« Reply #24 on: December 20, 2013, 09:55:18 AM »
If you are a very good welder, you could use the XBR tank base and weld an alternative top to it. Have a look here.... http://hoc.createforumhosting.com/my-xbr500-t6597-30.html
« Last Edit: December 20, 2013, 09:57:49 AM by JOOLZ »
guest1444
« Reply #25 on: January 02, 2014, 02:34:50 PM »
Thanks Joolz for the measurements - they give me a good idea of how it will fit a special I am building.
Looking forward to pix of your finished work, with the seat modified.
Matt
