Author Topic: Bottom yoke  (Read 646 times)
Bottom yoke
« on: September 16, 2013, 04:11:32 PM »
Im not holding up much hope that anyone might know, but here goes......Does anyone know of an alloy bottom yoke that will fit the XBR.
Re: Bottom yoke
« Reply #1 on: September 18, 2013, 09:05:51 AM »
Apparently the 600RR front end fits right on.
Re: Bottom yoke
« Reply #2 on: September 18, 2013, 10:56:42 AM »
Hi thanks I thought about going down that route, but the forks would be too long and would need quite a lot of work to sort out and I want to keep the standard top yoke as the 600 forks are a larger diameter
Re: Bottom yoke
« Reply #3 on: September 18, 2013, 11:10:43 AM »
The head bearings are the same inner and outer diameter?
Re: Bottom yoke
« Reply #4 on: September 18, 2013, 04:37:29 PM »
Hmmmm......don't take this as Gospel without confirming it, but I seem to remember the CX500/650 front end fitted on with little adaptation and gave you twin discs up front - if you get the Eurosport version you also get the Boomarang Comstar front wheel. As I said just double check  this before you buy anything.
Re: Bottom yoke
« Reply #5 on: September 18, 2013, 05:51:15 PM »
No that wouldnt work, I want to keep my original wheel
