Technical
Bike Problems/Questions
srx homemade exhaust questions
Topic: srx homemade exhaust questions (Read 1109 times)
guest668
April 01, 2013, 12:05:37 PM »
hi i came across this video on you tube in my quest to replace the exhaust on my srx400 with an alternative to going down the expensive predator route....was wondering if anyone has fitted a dunstalll or megaphone type exhaust on the srx and if so what are the pitfalls ....they tend to be smaller internal diameters so is it possible to use reducing rings.....would i need a link pipe? i have a y piece from a mini that fits the original downpipes.
many thanks and happy easter to all
Crowman
Re: srx homemade exhaust questions
April 10, 2013, 12:20:49 PM »
I'm doing something similar, have sourced a y piece and link pipes from Demon Tweeks and adaptors from an exhaust parts manufacturer. When it all arrives, I'll post an update.
guest668
April 11, 2013, 09:41:59 AM »
thanks for the reply crowman...will you be able to tell me what parts i need....i know i will need a y piece...but no sure about link pipes (If they need to be staright or have bend in them etc)....look forward to your update.
April 11, 2013, 06:33:56 PM »
Yvan used a Honda CB500 Y piece. It works fine.
Last Edit: April 12, 2013, 10:13:45 PM by SRXweb
guest668
April 12, 2013, 07:50:25 PM »
thanks for the reply srxweb...did yvan need a link pipe or did exhaust fit straight into Y piece?
Reply #5 on:
April 12, 2013, 10:28:27 PM »
http://srxteam.forums-actifs.net/t2305-echappement-home-made?highlight=echappement
He wrote the two standards exhaust pipes went directly in the Y piece from the CB500 exhaust line.
He now has adapted a Supertrapp slip-on muffler at the end of a BSM exhaust system. I don't heard yet the noise it makes.
http://www.servimg.com/image_preview.php?i=469&u=11937422
You can find this one in France :
http://moto-meca-soudure.fr/images/echappement/024.jpg
. I've never seen it fixed on a SRX. But it looks good.
guest668
Reply #6 on:
April 12, 2013, 10:46:27 PM »
sorry i meant did the muffler fit into y piece without need for link pipe...looks like he needed one on irst pic but what about with the supertrapp?
Reply #7 on:
April 12, 2013, 11:02:12 PM »
You are right. He needed a special pipe to fit perfectly the all things along the frame.
Concerning the Supertrapp, he "turned" a special piece in order to fix the muffler perfectly on the BSM special "expansion box"
You can see this piece on the second picture.
Dyslexics have more nuf
Reply #8 on:
April 18, 2013, 09:43:57 PM »
changing the subject a bit...I see you have an XT kick start fitted.... do you get on ok with it?
Technical
