Author Topic: removal of left hand crank case cover honda xbr  (Read 670 times)
guest1620
« on: February 20, 2013, 10:55:11 AM »
hi, please help if you can,  does the starter motor need to be removed to take of the left hand crank case cover on 85 xbr ? i have removed all bolts but the cover seems to be held on with a washer with a flat bottom where the starter motor pokes through into crank case cover, i just can't see how to remove it ! thanks, dave.
Re: removal of left hand crank case cover honda xbr
« Reply #1 on: February 21, 2013, 06:08:22 PM »
You shouldn't need to remove the starter motor itself, just the gears. That washer can get stuck on with oil but should come off if you wiggle it with a screwdriver  blade or similar. Once you have all the casing bolts out it can take a bit to break the seal on the gasket - sensible 'persuasion' with a rubber mallet usually work. You will probably need a new gasket as they tend to tear. I can send you the revelant section from the workshop manual if you need it - just PM me your email address.
guest1620
« Reply #2 on: February 21, 2013, 07:57:52 PM »
Thanks very much for the info, cover already persuaded loose with 'Thor's mighty hammer' , I will try and dig  out /loosen the  washer , once again thanks for the advice.
