assuming youve not got a clock, an alarm or imobiliser fitted you have one of two problems. eiher you have a duff new battery, or you have a wiring or electical fault in the loom. now in practice, if the ignition is turned off then everything will be dead. so, disconnect the battery and pit a bulb in between the terminal and the lead youve just disconnected. if everything is correctly working in the loom, the bulb will stay off. if the bulb lights up even at the dullest glimmer, then youve a fault in your loom. if the bike has a fuesbox it might be worth removing each fuse in trn to see if the bulb will go out and thus identify the circuit required. it might also be worth checking to see if the bike has a main relay or conactor, if this is being energised with the ignition off, then that might drain a battery over a period of ime.
