Author Topic: CB250RS OIL LEAK FROM CAM SPINDLES  (Read 1164 times)
« on: November 10, 2012, 05:44:01 PM »
Has anyone ever solved this old chestnut?
Dick Scratcher
Re: CB250RS OIL LEAK FROM CAM SPINDLES
« Reply #1 on: November 10, 2012, 11:08:26 PM »
Yep, certainly have and it's a right pain in the a***.................Honda's method according to the 'Official' workshop manual makes good reading but nothing else, remember that this was a 'budget' bike that Big H thought would be discarded after a very few years never to be resurrected never mind thirty years later.  The shafts are secured in place by parallel pins driven into the cam cover with very little access (I got my replacements plus shaft 'O' rings from David Silver) and this is how I shifted them...........Using a Dremel or equiv., undercut slight 'vees' in what part of the pins that you can get at, opposite sides obviously. Clamp the cover in a vice (tightly) and apply a pair of Mole 'vice' grips onto the pins as tight as you possibly can and then using a 'drift' against the jaws of the grips, hammer them away from the cover to draw the pins out. the grips after this abuse could well be scrap, mine were. CMM recommended the use of heat on the cover which is probably a good idea but be careful as the alloy (?) used is c**p and can distort or even disappear in front of your eyes as you're doing it. This really is brute force and goes totally against the grain with me but there's no real alternative that I can think of. This is a lot of hard work to replace two 'O' rings that cost next-to-nothing. Best of luck, pleased it's you and not me again !.
« Reply #2 on: November 11, 2012, 01:55:45 PM »
just as a tip, if you ever need to heat an ally part up to do stuff like this, clean it off first, apply a smear of oil on one side then heat the other side with a hot air paintstripper or blowlamp, when the smear of oil on the oter side gets hot enough to start smoking, then its hot enough.
« Reply #3 on: November 11, 2012, 11:26:38 PM »
Aye john,
Always worked well for me.
However, the fan oven also does a good job!  :o  ;)
Good health, Bill.
Dick Scratcher
« Reply #4 on: November 12, 2012, 08:32:38 PM »
I like the idea of a fan oven Themoudie but me putting oily bits in there would make definitely persona non grata in the hovel.
« Reply #5 on: November 12, 2012, 11:36:54 PM »
No problem Dick Scratcher.
Thoroughly degrease and put on an oven shelf. Place an old baking tray or roasting tin beneath the lump of metal, in case there is anything obnoxious left in any nooks and crannies, or absorbed by a slightly porous casting.
It helps when the process involves the repair of your wifes motorcycle! ;)
« Reply #6 on: November 14, 2012, 08:25:18 PM »
Thanks for posts guys.
