Author Topic: Non starting XBR  (Read 1119 times)
Non starting XBR
« on: October 17, 2012, 01:31:52 PM »
I've had my XBR laid up for the best part of a year now - various reasons but mostly crap weather!
I haven't been running it, but it has been kicked over from time to time.  I tried to start it the other day but absolutely no go. Fully charged battery, new petrol ( tank & carb drained before lay up) compression ... nothing. Engine is turning, fuel is getting through ( wet plug) but, with the plug resting on the head, no spark. I've tried changing the CDI and the cdi/plug cap and plug, still no spark, tried hotwiring the kill switch, no go....hmmmmm >:(
Last night I noticed on the wiring diagram there is a side stand cut out switch!....could be that but... where does the little bu55er live! Can anyone point me towards it and it's connector or even suggest something I haven't thought of? ???
The only thing I've done to the bike in lay up was to adjust the valve clearences, but I'm pretty sure I got it right.
thanks
guest1552
Re: Non starting XBR
« Reply #1 on: October 22, 2012, 08:59:34 PM »
I can only speak of my bike, but there is no side stand kill switch on it, it's a F reg!!
« Reply #2 on: October 23, 2012, 05:11:54 PM »
Just realised the wiring diagram I found marked up as 'XBR 500' actually says 'GB 500' in the top corner!.....No wonder I couldn't find the little bu66er!.......back to the drawing board. :(
guest1230
« Reply #3 on: October 29, 2012, 09:17:13 AM »
Mine was the exciter coil on the stator. Manual says check for continuity between the single wire from generator (Black/red I think) with earth. If no continuity its nakked. £115 from wemoto!
guest987
« Reply #4 on: October 29, 2012, 11:03:30 AM »
Check the carb. See if it is clean or gummed up. I know you have petrol getting through but the carb may still be a mess.
Hang just re read the post ???
Change the easy stuff, plug, plug cap, ht lead etc.................
As an alternative, check the kill switch, we have all done it >:(  but maybe some corrosion has set in......... :o
Rob
guest987
« Reply #5 on: October 29, 2012, 11:06:16 AM »
Just re read it again.\ I will STFU.......
guest833
« Reply #6 on: November 02, 2012, 08:09:35 AM »
If you need any parts, give me a shout, may have what you need, and I ain't webmoto prices!  :)
