Author Topic: SZR660 Water pump leak  (Read 560 times)
guest381
« on: June 13, 2012, 08:54:30 PM »
having bought a SZR recently all was going well until last week, after stopping and tuning the engine off I heard a fizz and a puff of steam from the exhaust. on further inspection I noticed a small drop of coolant coming from a hole in the bottom of the water pump. having done a search on the web I have found that the seal on the water pump side is suspect. What i'd like to know is if any other yamaha water pump seals will fit? the seal is only listed as part of the water pump housing for the the SZR. Any body had experience with this problem?
Re: SZR660 Water pump leak
« Reply #1 on: June 14, 2012, 07:14:06 PM »
if you can get the seal out intact, you could take it to a bearing factor and see if a stock off the shelf seal could fit it.
