Hello,
Sorry for my first post being a problem, but I'm having difficulties kickstarting a 1981 Honda CB250RS.
I finally got round to taking and passing my test a few months ago after, boh, over 8 years!! just pottering around on a 1973 C50. I bought a 2004 CBR125 2nd hand to do this, I kept that for a while but have now replaced it with the above. The 250's only done 17000 miles and is in excellent condition.
When I picked it up from the guy I checked first of all whether it was warm (and so potentially masking any starting cold problems) and then asked him to start it, he did this 2nd kick, no problems, though recommended that it needed a little throttle generally - although I thought the CB250RS had something to circumvent this need)
This was 22nd March. I brought it back home that evening and managed to start it after 6 or so kicks. However as this was late and right next to people's windows and the exhaust is custom and very loud I didn't keep it going for more than a minute.
Having finally got it taxed and insured and some time to go out on it, I just tried to start it this afternoon, but couldn't.
I turned the fuel valve on, ignition on, into neutral, engine stop switch to RUN, choke fully pulled out, hand on front brake, no throttle, straddling the bike I gently pushed kickstarter until I felt some resistance, then gave it a hard kick, but nothing. Tried a little throttle for a couple of times, nothing, very briefly did I get it started after about 30-40 attempts, but although I started revving it and was seeing around 5-6000rpm it died on me after about 10 seconds. Should I have really revved it to the redline at this point??? I then tried again, throttle off, throttle on, but couldn't start it again..
In case I flooded the engine, I turned the ignition off, fuel off, pushed choke down, open throttle fully, cranked the engine several times to clear it, then turned ignition no, fuel on, choke up etc...
I know the battery has nothing to do with it, although I think I should charge it anyway as the bike was SORN (it did come with a fresh day-old MOT) Surely the petrol can't be off? The seller started it fine, that's only
Am I maybe kicking too hard? I'm only used to the kickstart on a C50 so presumed this would need a hard kick.
Should I push gently until I feel resistance and then kick? Is it a good idea to try 2 kicks with the ignition off, choke down, and then ignition on, choke up?
If I get it starting, how hard should it need to be revved to stop it dying after 10 seconds? Surely it shouldn't need revving up to the redline to just keep it alive at this point?
Should I be twisting the throttle right at the end of the kick or does this just flood the engine for the next kick if that one fails?
One of the reasons I bought the RS was that I thought they were meant to be easy starters so it's most depressing to struggle like this.
Any pointers, help, even shaking of heads would be greatly appreciated.
Wilbur
