Author Topic: XBR Wiring/ petrol tank  (Read 1349 times)
500 T C
« on: February 19, 2012, 10:06:31 PM »
                   Does anyone out there, know where I can get a coloured wiring diagram from?Any input much appreciated.
      Petrol tank also has a few minor rust holes(leaking) any ideas?
Re: XBR Wiring/ petrol tank
« Reply #1 on: February 19, 2012, 10:29:19 PM »
Aye t.chainey,
I'm sorry, but I have no idea about the wiring diagram, an XBR loon maybe along soon! ;)
However, sealant for a motorcycle tank providing the holes aren't 'HUGE', might I suggest the stuff from Frost's?
Link to Frost's sealant: FROST'S TANK SEALANT
I hope this helps.
« Reply #2 on: February 19, 2012, 11:46:25 PM »
I've only ever seen the B&W one in the workshop manual. If you need a copy PM me your email.
500 T C
« Reply #3 on: February 20, 2012, 10:17:18 PM »
Bill,
      with regards to the wiring diagram      .,many thanks.
« Last Edit: February 22, 2012, 07:11:54 PM by t.chainey »
« Reply #4 on: February 21, 2012, 10:44:18 PM »
Aye t,chainey,
It's Steve#222 you need, I haven't anything XBR I'm afraid.
Also go canny about putting your email address up on the site, can be used I understand by scammers, but I'm not sure how.
If you hover the mouse over the two icons below our 'Avatars' on the left-hand side of the text box, you will see one icon for email and another for PM, that is what Steve was referring too.
Hope this helps.
« Reply #5 on: February 21, 2012, 11:29:04 PM »
Diagram sent, check your email.  ;)
Frog
« Reply #6 on: February 24, 2012, 10:57:38 AM »
Hi
for petrol tank leaks I have had good success with plastic padding leak fix. As long as the deteriorated area is small it works very well (has lasted a couple of years so far).
Knock any pinprick holes in with a ballpien hammer so they are below the surface, rough up the surface, make sure they are totally dry  then fill with the stuff, allow to set (its fast),  smooth off, paint and refill.
Frog
« Last Edit: February 24, 2012, 10:59:10 AM by Frog »
« Reply #7 on: February 24, 2012, 11:19:51 PM »
I keep a set of coloured pencils for marking up wiring diagrams.
