Author Topic: SLR650 shock - any alternatives?  (Read 581 times)
Frog
« on: November 07, 2011, 07:34:58 PM »
Hi
I am heavy (110kgs) and need a stiffer rear shock on my SLR650 - can anyone recommend an alternative to standard?
Preferably one that lowers it a little and one I  can get secondhand!
Frog
« Last Edit: November 07, 2011, 07:42:04 PM by Frog »
Frog
Re: SLR650 shock - any alternatives?
« Reply #1 on: January 29, 2012, 03:25:56 PM »
The answer to my question is a zxr400 shock - although it is not a straight bolt on swap.
The honda shock has 10mm eyes whilst the zxr ones are 12mm - I bushed the zxr shock with 12mm od 10mm id steel tube (B&Q). You need a new nut and bolt for the bottom shock mount.
Also needed to use all of the pre-load on the zxr shock (but I am heavy!).
One the road much improved - does not bottom out and less 'boingly'!
Lowers the bike - I would guess 20 -30 mm but the standard side stand is usable - just!
I am happy with it ;D
Frog
« Last Edit: February 02, 2012, 05:23:20 PM by Frog »
